Seger 123 Posted October 12, 2022 Posted October 12, 2022 (edited) Wie gewünscht implementiert, wie Sie im Bild sehen können, löscht es nach dem Hinzufügen das gelb unterstrichene Tag und stellt Kinderfilme ein. Ich habe nur 2 Filme in der Masse ausgewählt (Filter - alle Filme, die kein Tag haben). Das Hinzufügen funktioniert für die Auswahl der beiden Filme. Wenn ich jetzt alle Filme markiert (nicht simuliert, um sie sauber zu halten) hätte, wäre das andere Problem aufgetreten, dass es sie nicht alle verarbeitet hätte. Aber das machen wir später. Siehst du jetzt etwas? Edited October 16, 2022 by Seger
VicMoore 755 Posted October 14, 2022 Author Posted October 14, 2022 (edited) Hello Seger... I hope you are doing well. Have you made any progress on the problem that you are having? I would like to help you if I can. Vic... p.s. Seger, I just edited this post because I think I found your problem. The latest code is attached below. Let me know if it works for you. tool.zip Edited October 14, 2022 by VicMoore
VicMoore 755 Posted October 14, 2022 Author Posted October 14, 2022 (edited) Hello Seger... I have tested the bulk edit and I think it's working properly. The problem was that the tool was refreshing the page each time it saved data to a file. If you bulk edited 10 files then a refresh page was called after saving the metadata for each file was saved. This is why you saw the screen change so much. I appreciate you bringing this problem to my attention. Vic the code attached below is the same that was attached above. tool.zip Edited October 14, 2022 by VicMoore
VicMoore 755 Posted October 15, 2022 Author Posted October 15, 2022 (edited) You can now edit the tags and genres of locally playing Movies or tv shows. Several people have asked for this feature. I will now finish channel tagging. Vic tool.zip Edited October 15, 2022 by VicMoore 1
Seger 123 Posted October 16, 2022 Posted October 16, 2022 21 hours ago, VicMoore said: Sie können jetzt die Tags und Genres von lokal wiedergegebenen Filmen oder Fernsehsendungen bearbeiten. Mehrere Leute haben nach dieser Funktion gefragt. Ich werde jetzt die Kanalkennzeichnung abschließen. Vic tool.zip 5,36 MB · 3 Downloads I took the last code, it still changes everything, the message "LOADING PAGE - PLEASE WAIT" still appears. Unfortunately, the tool still overwrites all other tags (year, rating, etc.), and it also processes more films than I have selected via the filter. I have displayed all the tags that have no tags and then marked them all.
VicMoore 755 Posted October 16, 2022 Author Posted October 16, 2022 (edited) Seger, could you please tell me exactly what you are doing that causes these problems. I would like to duplicate what you are doing. So far I have not been able to duplicate what you are experiencing. I did find one problem. When you used the filter to select items with no tags, the items with no tags display OK. Then you selected all of the items with no tags by using "shift" click. What you see on the screen looks OK. Then you add or delete tags and click save. Now you see the "Waiting for page to load" message. The result is that all of the media is changed not just the ones with no tags. Is this what is happening? I see in the code how this can happen. The problem is in the "Select All." In other words "Shift" click. The code does not take the filter into consideration and selects everything in the folder, not just the items with no tags. I will fix this today. Vic Edited October 16, 2022 by VicMoore
Seger 123 Posted October 16, 2022 Posted October 16, 2022 2 hours ago, VicMoore said: Seger, könnten Sie mir bitte genau sagen, was Sie tun, das diese Probleme verursacht. Ich würde gerne wiederholen, was Sie tun. Bisher war ich nicht in der Lage, das zu wiederholen, was du erlebst. Ich habe ein Problem gefunden. Wenn Sie den Filter verwendet haben, um Elemente ohne Tags auszuwählen, werden die Elemente ohne Tags als OK angezeigt. Dann haben Sie alle Elemente ohne Tags ausgewählt, indem Sie mit der Umschalttaste klicken. Was Sie auf dem Bildschirm sehen, sieht OK aus. Dann fügen Sie Tags hinzu oder löschen sie und klicken auf Speichern. Jetzt sehen Sie die Meldung „Warten auf das Laden der Seite“. Das Ergebnis ist, dass alle Medien geändert werden, nicht nur die ohne Tags. Ist das was passiert? Ich sehe im Code, wie das passieren kann. Das Problem liegt bei "Alle auswählen". Mit anderen Worten: „Shift“-Klick. Der Code berücksichtigt den Filter nicht und wählt alles im Ordner aus, nicht nur die Elemente ohne Tags. Ich werde das heute beheben. Vic That's exactly what happened and that you found the error with "select all" is great! When you have the error with "select all" gone, we can move on to the rest. My films are all cleanly maintained with data via the database, I select that it should replace the existing TAG and add "children's films" to the test field. After that, all the previously maintained data like the year of release, ratings are no longer there. But as I said, let's get rid of the filter, then I'll send you another debug of my browser.
VicMoore 755 Posted October 16, 2022 Author Posted October 16, 2022 Thanks Seger... I will fix the bug tonight. After that I will move onto your next request. You have top priority. Vic
VicMoore 755 Posted October 17, 2022 Author Posted October 17, 2022 OK Seger -- problem fixed - give it a try. The code is attached below. I appreciate your help and testing. Now, what is the next thing? Vic tool.zip
Seger 123 Posted October 17, 2022 Posted October 17, 2022 10 hours ago, VicMoore said: OK Seger -- problem fixed - give it a try. The code is attached below. I appreciate your help and testing. Now, what is the next thing? Vic tool.zip 5.32 MB · 2 downloads Very good, the multiple selection worked. But look, it has set the tag "children's films" everywhere, I selected "Replace existing tags" and actually it should only set children's films for tags. But it also sets all other tags like the year, the rating and does not take over any tags. Am I perhaps selecting something wrong here? See pictures... -1666005087622.log
Seger 123 Posted October 17, 2022 Posted October 17, 2022 (edited) Can you recreate it? all the other tags are always deleted as well... Edited October 17, 2022 by Seger
VicMoore 755 Posted October 17, 2022 Author Posted October 17, 2022 I will recreate your test again ASAP Vic
VicMoore 755 Posted October 17, 2022 Author Posted October 17, 2022 OK - I duplicated the problem - I will fix it today - Thanks for your help Vic
VicMoore 755 Posted October 17, 2022 Author Posted October 17, 2022 Good morning Seger... I think I have all of your issues fixed. The two files that were changed are attached below. The problem was easy to fix but very hard to find. I greatly appreciate all of your help. I will continue testing today to make sure it works as expected. Let me know if you find any problems. Vic bulk.js editor.js
Seger 123 Posted October 17, 2022 Posted October 17, 2022 1 hour ago, VicMoore said: Guten Morgen Seger... Ich denke, ich habe alle Ihre Probleme gelöst. Die beiden geänderten Dateien sind unten angehängt. Das Problem war einfach zu beheben, aber sehr schwer zu finden. Ich schätze all Ihre Hilfe sehr. Ich werde heute weiter testen, um sicherzustellen, dass es wie erwartet funktioniert. Lassen Sie mich wissen, wenn Sie irgendwelche Probleme finden. Vic bulk.js 33,32 KB · 0 Downloads editor.js 61,17 KB · 0 Downloads Excellent, now we've done it, it's behaving as expected :-)!!!! Super job! You can post the "final" version for everyone once. The next topic I would like to test/tackle with you is the rating system for Germany. What I still noticed, is there actually a "I stay logged in function" so that he puts a token in the directory? See you in a few days and thanks again for your great work!
VicMoore 755 Posted October 17, 2022 Author Posted October 17, 2022 (edited) The latest code with all of the bug fixes is attached below Vic tool_1.0.zip Edited October 17, 2022 by VicMoore
VicMoore 755 Posted October 17, 2022 Author Posted October 17, 2022 Seger, when you are ready in a few days, I will be happy to help you with ratings. In the code I also fixed a small bug with locks. Vic
Cheesegeezer 3106 Posted October 17, 2022 Posted October 17, 2022 On 08/07/2021 at 14:42, VicMoore said: This tool bulk edits the metadata of Emby movies, TV shows, home videos, and photos. It can edit in two ways. In both the user selects one or more items to be edited. The first editing method, edits all of the selected items in bulk, applying the same Tags, Genres, Watched, Locks, People, and Studios to each item simultaneously. The second technique applies a metadata editor to each item, one item at a time, and it allows the user to edit all of the item's metadata. 1. add or remove tags and genres, 2. add or remove locks, 3. set watched or unwatched, 4. play movies, videos, audio files/music, and display photos, 5. display a TV guide or a channel list for VirtualTV and LiveTV (play shows from the TV guide) 6. apply filters to movies, videos, music, photos, and channel listings, 7. add tags and locks to one or more channels, 8. create a new Collection or add items to or remove items from an existing Collection, 9. create a new Playlist or add items to or delete items from an existing Playlist, 10. play a playlist, 11. add and remove Players and Studios, 12. and edit all metadata for Emby items. This tool is a single HTML file that includes HTML, CSS, Javascript, and jQuery. It has been tested on Chrome and Edge browsers (in a windows 10 environment). It may work on other browsers. I just don’t know. This code is free for anyone to use. It's my give back to the Emby community. A few screen shots are included below. -------------------------------------------------------------------------------------------------------------------------------------------- emby_new_tool_38.html 440.05 kB · 63 downloads Wow!! Nice work Vic, I seriously can’t believe i missed this. I’ll give this a shot when i get time but I believe this is a real game changer for many users. thanks for sharing
VicMoore 755 Posted October 17, 2022 Author Posted October 17, 2022 Hello CheeseBurger... Thanks for the kind words... Be sure to use the latest code Vic tool_1.0.zip
Happy2Play 9811 Posted October 17, 2022 Posted October 17, 2022 2 minutes ago, VicMoore said: Be sure to use the latest code This is the conflict of code being spread out over every post. Might want to go through your attachments to remove old code. In the forum go to your Name in upper right and use the drop down and select My Attachments faster removals. The issue of having code and troubleshooting in the same topic.
VicMoore 755 Posted October 17, 2022 Author Posted October 17, 2022 Thank you Happy2Play.... I am Lame when it comes to forums. Your advice is always good. I will delete old code posts. Vic
MBSki 1115 Posted October 17, 2022 Posted October 17, 2022 25 minutes ago, Happy2Play said: This is the conflict of code being spread out over every post. Might want to go through your attachments to remove old code. In the forum go to your Name in upper right and use the drop down and select My Attachments faster removals. The issue of having code and troubleshooting in the same topic. Is there an easy way to make this a plug-in? That would be easier for users to consume
VicMoore 755 Posted October 17, 2022 Author Posted October 17, 2022 Hello MBSki... I really don't know. I don't have any experience with plugins. Vic
MBSki 1115 Posted October 17, 2022 Posted October 17, 2022 42 minutes ago, VicMoore said: Hello MBSki... I really don't know. I don't have any experience with plugins. Vic Me neither. I'm hoping @FrostBytedoes.
Happy2Play 9811 Posted October 17, 2022 Posted October 17, 2022 1 hour ago, MBSki said: 1 hour ago, Happy2Play said: This is the conflict of code being spread out over every post. Might want to go through your attachments to remove old code. In the forum go to your Name in upper right and use the drop down and select My Attachments faster removals. The issue of having code and troubleshooting in the same topic. Is there an easy way to make this a plug-in? That would be easier for users to consume Not a coder just poke around in existing public plugins @chefpotentially can answer this. How to build a Server Plugin · MediaBrowser/Emby Wiki (github.com)
