GrimReaper 4895 Posted July 13, 2021 Posted July 13, 2021 Works like a charm. And it's even text-sensitive once list is pulled down, great.
VicMoore 755 Posted July 13, 2021 Author Posted July 13, 2021 Thanks for the kind words. The suggestions from everyone have made the tool much better. I fixed a few things that broke while I was adding code. My to do list is now empty Vic emby-tag-tool-14.html 1
GrimReaper 4895 Posted July 13, 2021 Posted July 13, 2021 Well then, here's another for the "to-do" list. Far from it being a rule, but happening often enough to get noticed: for some items - it applies both to the tags and genres - they don't render properly, i.e. continue offscreen, outside the box, either they get cut-off or sometimes whole words end up offscreen. Few examples attached.
VicMoore 755 Posted July 13, 2021 Author Posted July 13, 2021 That may be happening because the text lacks spaces so the lines can be broken up. I will work on it. Thanks for noticing the problem. You have sharp eyes. Vic
VicMoore 755 Posted July 13, 2021 Author Posted July 13, 2021 Try this. It should fix the problem. Vic emby-tag-tool-15.html 1
GrimReaper 4895 Posted July 13, 2021 Posted July 13, 2021 Yup, that did the trick, space after comma. Can't find any rogue items. Well done.
GrimReaper 4895 Posted July 13, 2021 Posted July 13, 2021 (edited) Minor observation, but why are TV Show libraries squared/flattened against Movie libraries normal ratioed posters? Edited July 13, 2021 by GrimReaper76
VicMoore 755 Posted July 13, 2021 Author Posted July 13, 2021 They can be any size you want. Each is configurable. What would you like them to be? I took the [ ] off the tag and genre lines. Vic emby-tag-tool-15.html
GrimReaper 4895 Posted July 13, 2021 Posted July 13, 2021 (edited) I'd prefer them uniformed across all libraries, to a standard poster aspect ratio, roughly 1:1.5 (2:3, for the puritans), but that's just me. Edited July 13, 2021 by GrimReaper76
VicMoore 755 Posted July 13, 2021 Author Posted July 13, 2021 How does this look. vic emby-tag-tool-15.html
jblaze12 8 Posted July 13, 2021 Posted July 13, 2021 Ok, how about....a list view instead of pictures? Reason I ask is because when I'm going through lots of movies it'd be awesome to have check boxes.
Happy2Play 9811 Posted July 13, 2021 Posted July 13, 2021 Just now, jblaze12 said: Ok, how about....a list view instead of pictures? Reason I ask is because when I'm going through lots of movies it'd be awesome to have check boxes. How would check boxes be any different then the ctrl-click?
jblaze12 8 Posted July 13, 2021 Posted July 13, 2021 14 minutes ago, Happy2Play said: How would check boxes be any different then the ctrl-click? If 800 movies were in a list with a checkbox next to each one it'd be a lot easier to tag faster (as opposed to scrolling down many, many times while holding down the ctrl button). It'd be even more awesome if the list had categories for genre and tag.
VicMoore 755 Posted July 15, 2021 Author Posted July 15, 2021 Attached below is the latest update to the tool. I added two buttons. One to mark the selected files as played and another to mark them as not played. I also removed from the code all of the code that I commented out during various experiments. Jblaze12, the GUI that you are suggesting would require rewriting how pages are composed. This would be a big deal. It's a good idea but for now I don't have the time to do it. Vic emby-tag-tool-16.html
VicMoore 755 Posted July 15, 2021 Author Posted July 15, 2021 I forgot to mention that I changed some background colors. I will list all of the colors below for completeness. Folder names have a brown background Tags have a red background Genres have a green background All buttons have a blue background with a light blue hover color
VicMoore 755 Posted July 15, 2021 Author Posted July 15, 2021 I added [P] and [NP] to the titles of videos to show if they have been played or not. I also turned off debugging. The tool should be faster now. Vic emby-tag-tool-17.html
GrimReaper 4895 Posted July 15, 2021 Posted July 15, 2021 (edited) Tbh, not a fan of [P] and [NP] in the title, seems invasive (or is it intrusive? pardon my english). Could you somehow make that optional, for those that want to use that function? Edit: Or make another line below green Genre (maybe yellow? light blue?) for Played/Unplayed status? Edited July 15, 2021 by GrimReaper76 Append
VicMoore 755 Posted July 15, 2021 Author Posted July 15, 2021 Yes, I understand. I plan to make it a badge on the image. So the [P] and [NP] are just for testing. Vic 1
VicMoore 755 Posted July 15, 2021 Author Posted July 15, 2021 OK GrimReaper76... I liked your idea of changing background colors. Now the title has a yellow background if it has already been played. It's white otherwise. Does this work for you? Vic emby-tag-tool-17.html
GrimReaper 4895 Posted July 15, 2021 Posted July 15, 2021 Good stuff, in this way it is very convenient.
jblaze12 8 Posted July 15, 2021 Posted July 15, 2021 7 hours ago, VicMoore said: Attached below is the latest update to the tool. I added two buttons. One to mark the selected files as played and another to mark them as not played. I also removed from the code all of the code that I commented out during various experiments. Jblaze12, the GUI that you are suggesting would require rewriting how pages are composed. This would be a big deal. It's a good idea but for now I don't have the time to do it. Vic emby-tag-tool-16.html 102.46 kB · 1 download No problemo, just thought I'd ask. I appreciate the work as it is now.
VicMoore 755 Posted July 15, 2021 Author Posted July 15, 2021 I cleaned up a few bugs and added some comments. Vic emby-tag-tool-18.html 1
MBSki 1115 Posted July 17, 2021 Posted July 17, 2021 25 minutes ago, Nico1320 said: Would this ever work for Live TV tags? That's exactly what I need it for...tagging the channels.
