VicMoore 755 Posted March 9, 2022 Author Posted March 9, 2022 Hello Horstepipe... I increased the field length to 200. If you want another length, just let me know. As for the other changes, I can't get to them until next week. I have some family obligations that I must attend to. All good stuff. Vic emby_new_tool_19.html 1
horstepipe 423 Posted March 11, 2022 Posted March 11, 2022 On 3/7/2022 at 3:18 PM, horstepipe said: sorry, one more thing I just noticed that Emby also stores trakt-ids. It would be really nice to also do the same with them like we are now able to do for imdb ids. We could import trakt lists quite easy then. and maybe rotten tomatoes ids, too?
horstepipe 423 Posted March 11, 2022 Posted March 11, 2022 57 minutes ago, VicMoore said: I will get to it next week Vic Thanks mate!
TIHTCM 1 Posted March 15, 2022 Posted March 15, 2022 This is an excellent and very useful tool. Thank you very much for all of your work on it. Would it be possible to also view Movies and Series by Folder name (physical location on server)? I have a number of movies filed by Genre (ie. Documentaries, Action, etc...). If I can view them by folder then I can bulk change the metadata of an entire folder using your tool. Thanks Again!
VicMoore 755 Posted March 16, 2022 Author Posted March 16, 2022 TIHTCM, try the code below. Click the filter tab and select the filter "Don't Show Folders" and select from the pulldown list the option "Show Folders". Afterword's, the folders will be displayed. Let me know if it works the way you expected. Vic emby_new_tool_19.html
VicMoore 755 Posted March 17, 2022 Author Posted March 17, 2022 Hello Horstepipe... I think you can use more prefixes than "imdb" when searching. The possibilities are "imdb", "tmdb", "tvdb", and "omdb." Give these a try and let me know if it works. I have not been able to find an emby API reference to trakt id's. Nor Have I found it while using emby. Can you tell me where you saw it? As for searching across multiple directories, the code is not organized to do this. To add this feature would require a major rewrite. Vic
horstepipe 423 Posted March 18, 2022 Posted March 18, 2022 7 hours ago, VicMoore said: Hello Horstepipe... I think you can use more prefixes than "imdb" when searching. The possibilities are "imdb", "tmdb", "tvdb", and "omdb." Give these a try and let me know if it works. I have not been able to find an emby API reference to trakt id's. Nor Have I found it while using emby. Can you tell me where you saw it? Vic hey there are links at the bottom of each movie, also a link to the Trakt site. But I don’t know how these are attached into the database…
horstepipe 423 Posted March 18, 2022 Posted March 18, 2022 7 hours ago, VicMoore said: As for searching across multiple directories, the code is not organized to do this. To add this feature would require a major rewrite. No problem, thanks for taking a look!
Happy2Play 9811 Posted March 18, 2022 Posted March 18, 2022 (edited) FYI the TRAKT link is per TMDBid. A url is created from the TMDBid. There is nothing specific to TRAKT in Emby database. https://trakt.tv/search/tmdb/85723?id_type=show https://trakt.tv/search/tmdb/632727?id_type=movie Or possibly IMDBid https://trakt.tv/search/imdb/tt8335332 Edited March 18, 2022 by Happy2Play added info 1
VicMoore 755 Posted March 19, 2022 Author Posted March 19, 2022 Thanks Happy2Play... I constantly learn new things from you. I appreciate your help. Vic
khalpin11 2 Posted March 20, 2022 Posted March 20, 2022 Sorry for the silly question, none of my forum searches on this thread returned any results. @VicMoore do you keep track of this html file in github or any other public version control tool? So I can keep track of the latest version of it without having to dig through forum posts? This is awesome! really appreciate the work!
VicMoore 755 Posted March 20, 2022 Author Posted March 20, 2022 Hello Khalpin11... I only post the code here. It's so simple that other measures are not needed. I appreciate you kind words. Vic
Happy2Play 9811 Posted March 20, 2022 Posted March 20, 2022 Easiest method is ensuring the first post has the current version of this tool. So ideally instead of placing in a new post the post can reference first post for updates.
VicMoore 755 Posted March 20, 2022 Author Posted March 20, 2022 Happy2Play, that same advice was given to me by GrimReaper, and I forgot to do it. I will do better starting tonight. Thanks for the help. Vic 2
horstepipe 423 Posted March 21, 2022 Posted March 21, 2022 (edited) On 3/18/2022 at 3:43 AM, Happy2Play said: FYI the TRAKT link is per TMDBid. A url is created from the TMDBid. There is nothing specific to TRAKT in Emby database. https://trakt.tv/search/tmdb/85723?id_type=show https://trakt.tv/search/tmdb/632727?id_type=movie Or possibly IMDBid https://trakt.tv/search/imdb/tt8335332 thanks for clarification! But for what I'd like to do this won't really help unfortunately. I'd like to use this tool to assign a genre to movies in lists like this: https://trakt.tv/users/benfranklin/lists/best-mindfucks?sort=rank,asc So I need to find a way to transform these list into a imdb or themoviedb list I guess. Thanks! Edited March 21, 2022 by horstepipe
horstepipe 423 Posted March 21, 2022 Posted March 21, 2022 On 3/7/2022 at 3:10 PM, horstepipe said: another thing I noticed: The "lock" field should be enabled by default as soon as you edit fields like genres, tags... as this also happens if you do it via the Emby UI. Hey Vic, hope I didn't overread it. What about this one?
horstepipe 423 Posted March 21, 2022 Posted March 21, 2022 16 minutes ago, horstepipe said: thanks for clarification! But for what I'd like to do this won't really help unfortunately. I'd like to use this tool to assign a genre to movies in lists like this: https://trakt.tv/users/benfranklin/lists/best-mindfucks?sort=rank,asc So I need to find a way to transform these list into a imdb or themoviedb list I guess. Thanks! looks like https://mdblist.com does what I need. I can import lists from rotten tomatoes and trakt and parse the imdb ids there, sweet
GrimReaper 4896 Posted March 21, 2022 Posted March 21, 2022 (edited) 11 minutes ago, horstepipe said: Hey Vic, hope I didn't overread it. What about this one? I vaguely recall the topic where it was suspected that Vic's tool is locking Genres - and it was not desired behavior (turned out it didn't), so I'd guess one could argue for both usage-cases. Gimme a min to see whether I can find it. Edit: Yep. Edited March 21, 2022 by GrimReaper Link
horstepipe 423 Posted March 21, 2022 Posted March 21, 2022 hmm yeah but then the tool behaves different to Emby's "native" metadata editor
horstepipe 423 Posted March 22, 2022 Posted March 22, 2022 hey Vic, sorry if I missed something, but what is the difference between "emby new tool" and "emby tag app"? Emby new tool is working here - when trying to use "emby tag app" I'm getting the CORS error we earlier talked about. Are there features in the "tag app" which are not in "new tool" and vice versa?
VicMoore 755 Posted March 24, 2022 Author Posted March 24, 2022 Sorry for the delay. I have been in bed sick. I will respond in more detail later. vic 1
VicMoore 755 Posted March 31, 2022 Author Posted March 31, 2022 Horstepipe, I am back I am much better now. You are right, there are two tools. GrimReaper, was kind enough to make a forum for the new tool, but I have failed to keep all of the comments for that tool on that forum. I am a slow learner. The new tool is a rewrite of the first tool (A tool for tagging emby content) which is the topic of this forum. The new tool lacks only the menus for tagging channels. I will be completing the rewrite for that in a few days. The first tool was motivated by my desire to learn the Emby API. So it contains lots of experiments that test that API. The rewrite removed all of this code, including code added for IPTV. I hope that I have been able to add the features that you need. Requests from users like you have made the tool a much better tool. If I can help you more, just let me know. Vic
horstepipe 423 Posted April 1, 2022 Posted April 1, 2022 glad that you recovered! thanks for the explanation, so I'm fine by keeping the new tool. Yes the script is very very useful, thanks again very much!
VicMoore 755 Posted April 2, 2022 Author Posted April 2, 2022 Attached below is the latest code. It adds the "LiveTV" for for virtualTV plugin. It lets you look at and play programs from the tv guide created by virtualTV . Vic emby_new_tool_20.html
