horstepipe 423 Posted February 19, 2022 Posted February 19, 2022 5 hours ago, VicMoore said: Yes, you can search on a Provider ID, but you can't search on an IMDB number. Vic Ok now I‘m confused? Where is the difference of these two?
Happy2Play 9811 Posted February 19, 2022 Posted February 19, 2022 5 hours ago, VicMoore said: Yes, you can search on a Provider ID, but you can't search on an IMDB number. Vic Not sure of context here as I have really been following or ready every post, but "AnyProviderIdEquals" will query specific id http://localhost:8097/emby/Items?Recursive=true&AnyProviderIdEquals=imdb.tt1160368&api_key={apikey}
VicMoore 755 Posted February 19, 2022 Author Posted February 19, 2022 Hello Happy2Play... I checked the Items API and I can search on having an IMDB provider, but I can't search for a specific IMDB. Am I wrong? Vic
Happy2Play 9811 Posted February 19, 2022 Posted February 19, 2022 5 minutes ago, VicMoore said: Hello Happy2Play... I checked the Items API and I can search on having an IMDB provider, but I can't search for a specific IMDB. Am I wrong? Vic The query I provided was by specific IMDBid, recursive is required. But note I am no expert and anything with the api.
VicMoore 755 Posted February 19, 2022 Author Posted February 19, 2022 I have missed that option. What API included it? I will try it ASAP. Vic
Happy2Play 9811 Posted February 19, 2022 Posted February 19, 2022 7 minutes ago, VicMoore said: I have missed that option. What API included it? I will try it ASAP. Vic Not sure but that is from /items
VicMoore 755 Posted February 19, 2022 Author Posted February 19, 2022 Horstepipe, I apologize. I was wrong. I looked through the options of that API many times and each time missed the item I needed. Happy2Play pointed it out to me, and I am very grateful. I will add the option to search on IMDB ids and it will be ready tomorrow for you to test. It's wonderful to learn something new. Vic
VicMoore 755 Posted February 19, 2022 Author Posted February 19, 2022 The ability to search on IMDB numbers is now in the main tool. The code is below. This was possible because Happy2Play showed me how to do it. Thanks again. Vic EmbyTagApp33.html
horstepipe 423 Posted February 19, 2022 Posted February 19, 2022 thank you very much @VicMoore and @Happy2Play! I will try this out asap
horstepipe 423 Posted February 19, 2022 Posted February 19, 2022 btw. If I access Emby Server normally via nginx, browser debug shows me this error: Access to XMLHttpRequest at 'https://url/emby/Users?IsHidden=false&IsDisabled=false&api_key=apikey' from origin 'null' has been blocked by CORS policy: No 'Access-Control-Allow-Origin' header is present on the requested resource. Do I need to add that header to my nginx config or is there another way to make it work (which is less safety impaired)?
horstepipe 423 Posted February 19, 2022 Posted February 19, 2022 @pir8radiomaybe an idea? I’m basically using your nginx config.
pir8radio 1313 Posted February 19, 2022 Posted February 19, 2022 2 hours ago, horstepipe said: @pir8radiomaybe an idea? I’m basically using your nginx config. whats the issue, just the error above? 1
horstepipe 423 Posted February 20, 2022 Posted February 20, 2022 (edited) 6 hours ago, pir8radio said: whats the issue, just the error above? Yes, and the tool doesn’t load anything - so unusable… can post a screen tomorrow. thanks Edited February 20, 2022 by horstepipe
VicMoore 755 Posted February 20, 2022 Author Posted February 20, 2022 Good morning Horstepipe... I can't help with this problem because I know nothing about nginx. If you discover the problem and need me to change something, just let me know and I will do it if possible. I have attached another tool below that you might want to try and see if it works in your environment. Vic emby_new_tool_16.html
horstepipe 423 Posted February 21, 2022 Posted February 21, 2022 (edited) 23 hours ago, VicMoore said: Good morning Horstepipe... I can't help with this problem because I know nothing about nginx. If you discover the problem and need me to change something, just let me know and I will do it if possible. I have attached another tool below that you might want to try and see if it works in your environment. Vic emby_new_tool_16.html 248.92 kB · 4 downloads thank you very much! This version seems to solve that problem. about the imdb IDs: searching for one ID works without problems! But if I search for two IDs, only one movie is being shown. So e.g. from your example, first is Ghostbusters and second is eternals imdb.tt4513678,imdb.tt9032400 only Eternals is being shown. If I change the order vice versa imdb.tt9032400,imdb.tt4513678 only Ghostbuster shows up. Hopefully you can fix that Also it would be nice to filter over multiple libraries, e.g. 4k movies and "normal" movies - so I can add genres/tags to all versions directly - not sure whether this is possible via the api. Thank you very much again! Edited February 21, 2022 by horstepipe
Charles Bosquet 0 Posted February 21, 2022 Posted February 21, 2022 Hello @VicMoore ! Some news for the field with "No Tagline" ? Thank you very much. Charly
VicMoore 755 Posted February 21, 2022 Author Posted February 21, 2022 Good morning Horstepipe... Interesting, I never checked to see if multiple Ids worked. The API specifically states that a comma delimited list of Ids is allowed. I will check it ASAP. Vic
VicMoore 755 Posted February 21, 2022 Author Posted February 21, 2022 Thanks Charles, for the kind words. Vic
VicMoore 755 Posted February 21, 2022 Author Posted February 21, 2022 Good morning Horstepipe... I checked my code and the request to the API was correct. So, I posted a request on the API forum asking if the API was working properly. Luke said the API only returns one result. He further said that He would fix the problem in the next Emby release. Vic 1
horstepipe 423 Posted February 22, 2022 Posted February 22, 2022 8 hours ago, VicMoore said: Good morning Horstepipe... I checked my code and the request to the API was correct. So, I posted a request on the API forum asking if the API was working properly. Luke said the API only returns one result. He further said that He would fix the problem in the next Emby release. Vic Thanks for caring about that, will try it out with the next server beta!
GokuTradeDevil 14 Posted February 22, 2022 Posted February 22, 2022 Hi everyone , i would like to tag a show from the tv guide and looks that i can't, and with emby it tags the entire channel ! So my question is if that is posible cause i want to hide some shows ! Thanks !
VicMoore 755 Posted February 23, 2022 Author Posted February 23, 2022 (edited) GokuTradeDevil, you can tag individual TV shows, seasons, and series with the tag tool. The latest code is attached below. Keep in mind that these tags are placed only on Emby content, not on IPTV content. Vic EmbyTagApp33.html Edited February 23, 2022 by VicMoore
GokuTradeDevil 14 Posted February 23, 2022 Posted February 23, 2022 32 minutes ago, VicMoore said: GokuTradeDevil, you can tag individual TV shows, seasons, and series with the tag tool. The latest code is attached below. Keep in mind that these tags are placed only on Emby content, not on IPTV content. Vic EmbyTagApp33.html 273.82 kB · 1 download Thank you , what i need is to tag the epg content but is a emby limitation for now , hope in the next updates we can do this and more, like tag to favorite and so on !
VicMoore 755 Posted February 23, 2022 Author Posted February 23, 2022 Is your EPG from virtualTV or IPTV? Vic
GokuTradeDevil 14 Posted February 23, 2022 Posted February 23, 2022 1 hour ago, VicMoore said: Is your EPG from virtualTV or IPTV? Vic It's a xml file from my satellite decoder box
