akacharos 32 Posted February 11, 2022 Posted February 11, 2022 What a lovely tool! Thanks VicMoore!! Just an idea: do you think it is possible to generate collections based on tags? So you would filter a listing and then given the option to add these to a collection. That would rock
Charles Bosquet 0 Posted February 11, 2022 Posted February 11, 2022 Hi Vic It's just great, all this time spent on each version: well done. Thanks for all that work.
VicMoore 755 Posted February 11, 2022 Author Posted February 11, 2022 Good morning Akacharos... Two tools are being developed here together. The tool attached below can make collections and playlists from tags. Vic EmbyTagApp31.html 1
Tremas 205 Posted February 11, 2022 Posted February 11, 2022 Hello @VicMoore, thanks for all of your great work on these tools. It's clear you are learning quite a bit about emby because I am learning a lot just by following the thread. One thing that I have always wondered about is how emby handles local trailers. If you have video files with "-trailer.ext" in the name, emby will make the video available with a trailer button on the movie info page. However, it is not exposed anywhere else in the UI. To my knowledge, you cannot add metadataor build a playlist of trailers. Metadata is not very useful, but I would be interested in building playlists of trailers to help decide what I want to watch next from my backlog. Are local trailers a media type that is exposed in the API and something that your tool could add to a playlist or collection? Thanks again for all of your efforts.
VicMoore 755 Posted February 12, 2022 Author Posted February 12, 2022 Good morning Tremas... Yes, I am learning a lot. I appreciate your comments and you pose an interesting question. I have never tried to tag trailers or put them in a playlist. I will try to do so and let you know the outcome. Vic
VicMoore 755 Posted February 12, 2022 Author Posted February 12, 2022 Tremas... I changed the code to display trailers. You can now select an assortment of trailers and put them into a playlist. The resulting playlist will play in Emby. I am still trying to figure out why they don't play in the tool. The new code is attached. Vic EmbyTagApp32.html 1
Tremas 205 Posted February 12, 2022 Posted February 12, 2022 That’s great! I will check it out later this weekend.
Tremas 205 Posted February 13, 2022 Posted February 13, 2022 Hi @VicMoore, I guess I need some help. Once I select a movie, how do I add the trailer and not the full film to a playlist? Or is there another section where trailers are listed? Thanks!
VicMoore 755 Posted February 14, 2022 Author Posted February 14, 2022 (edited) Tremas, you don't select the movies. Go to the emby trailer folder and select the trailers that you want for your playlist. Vic p.s. make sure that you have installed the trailer plugin. Edited February 14, 2022 by VicMoore
GrimReaper 4896 Posted February 14, 2022 Posted February 14, 2022 13 minutes ago, VicMoore said: Tremas, you don't select the movies. Go to the emby trailer folder and select the trailers that you want for your playlist. Vic p.s. make sure that you have installed the trailer plugin. Vic, user was talking about local trailers, which can be found in two places: either in movie folder named <moviename>-trailer.ext or within \trailers subfolder in movie folder. 1 1
VicMoore 755 Posted February 14, 2022 Author Posted February 14, 2022 Thanks for clarifying that. Sometimes I am a bit slow I need to think about this. Vic
DataHoarder 0 Posted February 14, 2022 Posted February 14, 2022 I have just tested editing Genres and Tags on a 'Home Video & Photos' library, and no changes were applied. Am I doing something wrong, or are 'Home Video & Photos' libraries not supported?
Charles Bosquet 0 Posted February 14, 2022 Posted February 14, 2022 Hello Vic. French again! With version 32 of the xml file, the "Tagline" field when empty automatically adds "No tagline" which remains visible on the devices. A way to avoid this? Thanks again. vs.
VicMoore 755 Posted February 14, 2022 Author Posted February 14, 2022 (edited) I will check out both of these problems ASAP Vic P.S. Yes Charles, I will remove the "No Tagline" today. I put it in for debugging. I should have removed it, but forgot Edited February 14, 2022 by VicMoore
horstepipe 423 Posted February 14, 2022 Posted February 14, 2022 hey @VicMoore I was just about trying out your tool. Unfortunately after logging in the page stays at Loading Page, Please Wait! in DevTools I'm seeing this: Uncaught RangeError: Maximum call stack size exceeded at myConsoleLog (EmbyTagApp29.html:4289:30) at myConsoleLog (EmbyTagApp29.html:4293:21) at myConsoleLog (EmbyTagApp29.html:4293:21) at myConsoleLog (EmbyTagApp29.html:4293:21) at myConsoleLog (EmbyTagApp29.html:4293:21) at myConsoleLog (EmbyTagApp29.html:4293:21) at myConsoleLog (EmbyTagApp29.html:4293:21) at myConsoleLog (EmbyTagApp29.html:4293:21) at myConsoleLog (EmbyTagApp29.html:4293:21) at myConsoleLog (EmbyTagApp29.html:4293:21) DevTools failed to load source map: Could not load content for https://cdn.jsdelivr.net/npm/hls.min.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE Any idea? Best regards
horstepipe 423 Posted February 14, 2022 Posted February 14, 2022 On 1/20/2022 at 7:48 PM, VicMoore said: Yes, filter on ratings is easy to do. At the moment I am fully occupied with home duties for the wife. I will add this soon. On another topic, Horstepipe, I have not forgotten your request. It's not easy to do. I will let you know soon if I can do it. Vic No rush, but did you figure out whether this is possible? Best regards!
VicMoore 755 Posted February 14, 2022 Author Posted February 14, 2022 hello Horstepipe... I have been thinking about your request. I have to break it down into available APIs. I have a question. Would it be helpful if I allowed you to search on IMDB ids? then you could select and tag the search results. Just an idea. Vic
VicMoore 755 Posted February 14, 2022 Author Posted February 14, 2022 Hello DataHoarder... Try the code below. I tested it and it worked fine for tagging Home Videos. Vic EmbyTagApp32.html
horstepipe 423 Posted February 15, 2022 Posted February 15, 2022 8 hours ago, VicMoore said: hello Horstepipe... I have been thinking about your request. I have to break it down into available APIs. I have a question. Would it be helpful if I allowed you to search on IMDB ids? then you could select and tag the search results. Just an idea. Vic Yes, that is what my request basically is about search for multiple IMDb IDs -> assign a tag to the results
horstepipe 423 Posted February 18, 2022 Posted February 18, 2022 On 2/15/2022 at 3:10 AM, horstepipe said: Yes, that is what my request basically is about search for multiple IMDb IDs -> assign a tag to the results optionally it outputs a list of movies (imdb ids) which are not available at Emby server.
VicMoore 755 Posted February 18, 2022 Author Posted February 18, 2022 Good morning Horstepipe... I have tried several ways to search on IMDB numbers and none were suitable. Emby allows searching on "having an IMDB number" but not on a specific number. In my tool, all of the magic is actually being provided by Emby. I just activate API's. This is the key separator between Plex and Emby. The list of APIs in Emby is impressive, but unfortunately it does not include what you have requested. As I learn and my abilities grow, I may be able to solve your problem in the future. I will keep it in mind. Vic
horstepipe 423 Posted February 18, 2022 Posted February 18, 2022 2 hours ago, VicMoore said: Good morning Horstepipe... I have tried several ways to search on IMDB numbers and none were suitable. Emby allows searching on "having an IMDB number" but not on a specific number. In my tool, all of the magic is actually being provided by Emby. I just activate API's. This is the key separator between Plex and Emby. The list of APIs in Emby is impressive, but unfortunately it does not include what you have requested. As I learn and my abilities grow, I may be able to solve your problem in the future. I will keep it in mind. Vic thank you very much for taking a look at it! I googled around here in the forum, look at this post: maybe this helps?
horstepipe 423 Posted February 18, 2022 Posted February 18, 2022 2 hours ago, VicMoore said: Good morning Horstepipe... Emby allows searching on "having an IMDB number" but not on a specific number. @Luke if you have a minute, any input about that?
VicMoore 755 Posted February 18, 2022 Author Posted February 18, 2022 Yes, you can search on a Provider ID, but you can't search on an IMDB number. Vic
