Brudertac 18 Posted July 7, 2021 Posted July 7, 2021 Hi all, Emby 4.6.4.0 is running on my DS1019+ on Docker... Transcoding h265 Movies works fine without HDR Tone Mapping. If i enable Tone Mapping (only with Hardware) it fails and switch to Software Transcoding. Is that the exprected behaviour for the DS1019+? Thanks! best regards Brudertac hardware_detection-63761267309.txt
Carlo 4561 Posted July 7, 2021 Posted July 7, 2021 Could you post a ffmpeg file from a 4K tone map please?
Brudertac 18 Posted July 7, 2021 Author Posted July 7, 2021 10 minutes ago, cayars said: Could you post a ffmpeg file from a 4K tone map please? Here it is. ffmpeg-transcode-807aa87a-55f5-46f0-a3b0-69767eed2c7c_1.txt
Carlo 4561 Posted July 8, 2021 Posted July 8, 2021 Hi could you try 1 or 2 other HDR movies and upload the ffmpeg log for those as well? Thanks you
Brudertac 18 Posted July 8, 2021 Author Posted July 8, 2021 6 hours ago, cayars said: Hi could you try 1 or 2 other HDR movies and upload the ffmpeg log for those as well? Thanks you Sure. Here they are.. ffmpeg-transcode-09e33113-61d5-423a-b014-649e32188797_1.txt ffmpeg-transcode-c52a5612-0add-47d8-9bc2-c2ba860e8e00_1.txt
Carlo 4561 Posted July 8, 2021 Posted July 8, 2021 @softworkz Can we have your words of wisdom on this? 1 1
softworkz 5133 Posted July 9, 2021 Posted July 9, 2021 On 7/8/2021 at 3:13 PM, cayars said: @softworkz Can we have your words of wisdom on this? That CPU includes Intel HD Graphics 500 which doesn't support VAAPI native tone mapping. Please install the Emby Diagnostics Plugin and choose Extra-T for VAAPI tone mapping. 1
Brudertac 18 Posted July 9, 2021 Author Posted July 9, 2021 1 hour ago, softworkz said: That CPU includes Intel HD Graphics 500 which doesn't support VAAPI native tone mapping. Please install the Emby Diagnostics Plugin and choose Extra-T for VAAPI tone mapping. Thanks but that do not work. Still Software Mode... ffmpeg-transcode-2ed4ae43-1f67-4b10-9472-be315979bf13_1.txt
softworkz 5133 Posted July 9, 2021 Posted July 9, 2021 Oh, that's a different issue. How/from where did you install Emby? Thanks
Brudertac 18 Posted July 9, 2021 Author Posted July 9, 2021 9 minutes ago, softworkz said: Oh, that's a different issue. How/from where did you install Emby? Thanks It is an Docker Image from Linuxserver... I think there is a Problem. Currently i setup Emby direct on my Synology (DSM 7) and try that. I will write here when i have testet this... Thanks
Carlo 4561 Posted July 10, 2021 Posted July 10, 2021 Yes, please let us know how you make out with a direct install on DSM 7.
Solution Brudertac 18 Posted July 10, 2021 Author Solution Posted July 10, 2021 (edited) Yeah, with Emby Installed directly on DSM7 it works perfect. I had to use the Emby Diagnostics Plugin and choose Extra-T for VAAPI tone mapping. Thanks @cayars and @softworkz Edited July 10, 2021 by softworkz 1
softworkz 5133 Posted July 10, 2021 Posted July 10, 2021 @Brudertac Thanks for the feedback! It's a bit difficult at the moment to take the right actions because we are facing several different issues that are all affecting tone mapping. VAAPI incorrectly indicates support for native tone mapping for hardware where it isn't (meant to be) supported (fails of course) VAAPI Native Tone Mapping has at least one known bug which causes TM to fail even though it is meant to be supported (bug status depends on the Intel driver version) The alternative TM method - Extra-T (OpenCL) - is working on a wider range of hardware, but getting OpenCL set up correctly is not an easy task. Most of our official Linux type packages are including an appropriate OpenCL setup out of the box; for containerized targets though, OpenCL is not expected to work at all (in regular cases) 6 hours ago, Brudertac said: Yeah, with Emby Installed directly on DSM7 it works perfect. I had to use the Emby Diagnostics Plugin and choose Extra-T for VAAPI tone mapping. Thanks @cayars and @softworkz Yeah, without doubt that's the best choice in your case. 1
Brudertac 18 Posted July 10, 2021 Author Posted July 10, 2021 Thanks @softworkzfor the detailed insight. I see, not easy to Handle right now. But it is -again- great to see how awesome the Emby Team works. Thanks alot! 2
