rodainas 191 Posted July 9, 2021 Posted July 9, 2021 6 minutes ago, mw420blazeit said: the mpv stats shown are for the high10 file thats not high10. pixel format is 8 bit NV12 yuv pixel format. YUV 4:2:0 image with a plane of 8 bit Y samples followed by an interleaved U/V plane containing 8 bit 2x2 subsampled colour difference samples. This is high10
mw420blazeit 2 Posted July 9, 2021 Author Posted July 9, 2021 2 minutes ago, rodainas said: thats not high10. pixel format is 8 bit NV12 yuv pixel format. YUV 4:2:0 image with a plane of 8 bit Y samples followed by an interleaved U/V plane containing 8 bit 2x2 subsampled colour difference samples. This is high10 Well emby reports the same file as high10 so I don't know
Guest Posted July 9, 2021 Posted July 9, 2021 That might imply there's a metadata issue with either the video or the container. Which also might explain why emby is doing what it's doing. Try remuxing it in mkvtoolnix.
Carlo 4561 Posted July 9, 2021 Posted July 9, 2021 If you have or can install MediaInfo, it would be nice to see how this program reports this.
mw420blazeit 2 Posted July 9, 2021 Author Posted July 9, 2021 2 hours ago, cayars said: If you have or can install MediaInfo, it would be nice to see how this program reports this. mkv_MediaInfo.txtI guess mpv android is giving wrong information cause everywhere else it says 10bit but then how is mpv able to HW decode it properly
Guest Posted July 9, 2021 Posted July 9, 2021 Play it directly in mpv and not through emby as an external player. What do the stats tell you?
ebr 16338 Posted July 10, 2021 Posted July 10, 2021 The TV app is transcoding because this is a generic box so we're assuming it cannot handle profile level 5.1. We can try adjusting that assumption and see if it causes problems elsewhere.
neik 874 Posted July 10, 2021 Posted July 10, 2021 1 hour ago, ebr said: The TV app is transcoding because this is a generic box so we're assuming it cannot handle profile level 5.1. We can try adjusting that assumption and see if it causes problems elsewhere. Wouldn't it be better to ask the hardware to tell its capabilities? Is that even possible? Just wondering...
ebr 16338 Posted July 11, 2021 Posted July 11, 2021 20 hours ago, neik said: Wouldn't it be better to ask the hardware to tell its capabilities? Is that even possible? Yes and we try to do that in most cases.
neik 874 Posted July 11, 2021 Posted July 11, 2021 (edited) 3 hours ago, ebr said: Yes and we try to do that in most cases. Why not here, special reason? Edited July 11, 2021 by neik
