crusher11 1145 Posted July 6, 2021 Posted July 6, 2021 At the moment, Emby is set to use the Australian system. The Australian ratings are available in the drop-down when editing metadata. But not all films are rated in Australia. So why not let me use the UK or US ratings in these cases? 2
Cheesegeezer 3106 Posted July 7, 2021 Posted July 7, 2021 Could you not just select a AUS equivalent. 1
Luke 42246 Posted July 7, 2021 Posted July 7, 2021 The reason you only see options based on your configuration is to avoid overwhelming you with choices for all countries. But yes, ideally, this should be possible. 1
crusher11 1145 Posted July 8, 2021 Author Posted July 8, 2021 17 hours ago, Cheesegeezer said: Could you not just select a AUS equivalent. Not all ratings are really that equivalent. Australia doesn't even have an "unrated" rating.
minkshaman 2 Posted September 27, 2021 Posted September 27, 2021 I came looking for this exact thing. A lot of US shows don't have an AUS rating and I don't want to have to manually add a rating to each show. Simply adding the US rating would make sense and be a lot simpler!
