For propel who update their Synology to 7.0 and stop at /volume1 can't share their folder
kao_solid
Before the new update I just go to
(control panel) then (user & Group) then choose the user (emby) - (EDIT) - (Permissions) and mark read/write for the the folder I want emby to share.
But this is not working any more still can't add the folder to the library it will stop at /volume1
You need to give the permission in the shared folder it self for each share you want emby to access.
here is what you need to do:
1- Go to Control Panel and select shared folder.
2- Select the share which contains your media and click Edit
3- Click the Permission tab.
4- Change the dropdown from Local Users to System internal user.
5- Check the read/write checkbox for the Emby user.
6- Click save to confirm the new permission.
Don't forget this must be done for each share folder you wanted to be added. This is really annoying if you got many folders but you will do it one time any way.
Hopefully this will be helpful
  • Like 2
  • Agree 1
Hi, thanks for the info !
  • Like 1
