c0m3r 95 Posted August 26, 2014 Posted August 26, 2014 Hi @@chessdragon136 noticed a small issue. When playback end and the app returns to the episode/movie screen, there appears to be no artwork with just a grey background as per attached pic. Any ideas?
chessdragon136 677 Posted August 26, 2014 Posted August 26, 2014 I can't reproduce :S If you return from that page and go to the item do you got a background image?
c0m3r 95 Posted August 26, 2014 Author Posted August 26, 2014 Yes all works fine. Also just had a strange issue where all it showed was the backdrop and nothing else until i pressed return. Only happens if i let the video end, not by stopping it manually
CBers 7554 Posted August 26, 2014 Posted August 26, 2014 @@c0m3r - I can't reproduce your issue either. I played a couple of videos to the end, but everything looked OK when they stopped playing.
c0m3r 95 Posted August 26, 2014 Author Posted August 26, 2014 Strange, is happening every time here. Will keep an eye on it see if it continues.
crashkelly 62 Posted August 26, 2014 Posted August 26, 2014 Cannot reproduce this either Cheers CrashKelly
