justinrh 264 Posted July 5, 2021 Posted July 5, 2021 (edited) Last night I was watching a movie on the ol' Shield and after about 25min Emby popped up a message about exceeding streaming limit. I'm the only user and only that device was being used. I started the video again and about 20min later I got the same error again. I think two shows were being recorded at the same time via the DVR. I had the Network -> max streams limit =1. (I forgot I recently changed it from unlimited.) I suspect the streams limit is the cause, but two questions: 1) I had only one stream (the video I was watching), so why the error? 2) Why the error only after ~20 minute intervals? Would a server log help explain? Edited July 5, 2021 by justinrh
ebr 16309 Posted July 5, 2021 Posted July 5, 2021 Hi. Exactly what did the message say and what did it look like? And, yes, a server log from when this happens would be helpful.
justinrh 264 Posted July 5, 2021 Author Posted July 5, 2021 I don't remember exactly, something like 'max stream limit exceeded'. embyserver-63761039995.txt
ebr 16309 Posted July 5, 2021 Posted July 5, 2021 When, in that log, did the problem occur? The streaming limit is only checked at playback start so were you starting something new?
Carlo 4561 Posted July 5, 2021 Posted July 5, 2021 I bet another user logged in and starting streaming something and since the limit was set to 1 only 1 stream is allowed on the server.
ebr 16309 Posted July 5, 2021 Posted July 5, 2021 That would have produced the error for the other user. One scenario I can imagine would be some sort of playback error causing the app to re-try, which then could produce this situation if the max stream limit was only 1 on the server.
justinrh 264 Posted July 5, 2021 Author Posted July 5, 2021 As said, it happened after ~20min, twice. No other user was connected (unless you consider the DVR a user). Best I can tell, it looks like the first time it happened was at 2021-07-04 19:13:37.691.
ebr 16309 Posted July 6, 2021 Posted July 6, 2021 If you raise the limit to 2 does the problem go away?
justinrh 264 Posted July 6, 2021 Author Posted July 6, 2021 I've set it back to unlimited and haven't used it since. I'll let you know if it pops up again and maybe get a screenshot.
Luke 42202 Posted July 7, 2021 Posted July 7, 2021 18 hours ago, justinrh said: I've set it back to unlimited and haven't used it since. I'll let you know if it pops up again and maybe get a screenshot. Great, thanks !
