Abobader 3485 Posted July 5, 2021 Posted July 5, 2021 Good day @Luke I can not belive this myself, but seem last month by mistake I update my Emby beta last month and seems (blame it on the web site, since I always download from the same location) I got the the ver for DSM 7! As you see now, the system files on the "/volume1/@appstore/EmbyServer" and the configs files and data, and everything else on: "/volume1/Emby" Here images: Now what the best option to do, let say I want to update later on to DSM 7, as we consider the issue above. Thanks in advance. My best
Abobader 3485 Posted July 5, 2021 Author Posted July 5, 2021 btw @Luke This location: "/volume1/@appstore/EmbyServer" is we used to the location for Emby server install in the old times.
Abobader 3485 Posted July 5, 2021 Author Posted July 5, 2021 @Luke I just check the website for the download, and as you see where the problem are:
Carlo 4561 Posted July 5, 2021 Posted July 5, 2021 (edited) Are you saying the DSM 6 page for 64-bit NAS beta is pointing to a DSM7 file? Unless it got mixed up while building the filename for beta on both DSM 6 and DSM 7 are correct. Edited July 5, 2021 by cayars
Abobader 3485 Posted July 5, 2021 Author Posted July 5, 2021 I think it was a mistake from Luke, but he is the only one can confirm this. (regarding the download link for DSM 6).
Luke 42243 Posted July 6, 2021 Posted July 6, 2021 That's the DSM 6 page, although they should be flipped now.
Abobader 3485 Posted July 6, 2021 Author Posted July 6, 2021 Good day, This thread not to blame anyone, it's more than what I should do next, I better fix this myself when no one from the family using the Synology. Topic close. My best
