fetty651 0 Posted July 3, 2021 Posted July 3, 2021 I've been having some issues with my dynamic images since the update. I have been converting my library of audiobooks from WAV to FLAC. Around when the update happened recently I lost all of my dynamic images. There is nothing to delete when I go into images and no matter how many times I restart my sever/scan my library folders, they never repopulate. My movies and photos still create dynamic images however, just not the audiobooks. I'm willing to create the images for the files, but if I can have the dynamic images back, I would really like that. Could I be missing something in my folder hierarchy? I currently have it like this: (Main Library folder)/Fiction --> (Subfolder)/Book --> (files in folder)/FLAC files and a JPG named "folder" Changing the music folder structure doesn't seem to change how it sees the images. Individual images for the books get picked up, but they used to also populate the dynamic images. Any help would be appreciated.
Carlo 4561 Posted July 3, 2021 Posted July 3, 2021 Hi, not sure I know the answer to why they aren't generating (yet) but as a test if you create a new library and move 4 audiobooks (with graphics) into the new library will it auto generate the image for those 4 audio books? If so you could grab a copy of the new image to use temporarily (if needed). But this could help us diagnose if dynamic images are being generated for a new library ok.
fetty651 0 Posted July 26, 2021 Author Posted July 26, 2021 (edited) I have figured it out. Sorry for the super late response. After the update, I had removed and re-added some libraries to get them functioning again. For some reason, it seems like if you attempt to add multiple libraries at the same time, it causes the dynamic images to freak out. I don't know exactly why this is, but when going one by one, everything seems to be fine. Don't know if this is worth looking into, but I wouldn't have known not to do this otherwise. Edited July 26, 2021 by fetty651
Luke 42200 Posted July 29, 2021 Posted July 29, 2021 Hi, glad to hear it's working. The dynamic images do not freak out. They rotate periodically automatically. Thanks for the feedback.
fetty651 0 Posted August 2, 2021 Author Posted August 2, 2021 The issue was that they weren't rotating at all. They weren't even populating to begin with.
