NelsonSilva 1 Posted July 3, 2021 Posted July 3, 2021 Hello, I´m trying to add https://synology.emby.media/ in the NAS DS920+ but I´m getting a Invalid Location. I can ping the URL (see below) but if I try to open the link with chrome or edge i´m getting a "can't reach this page" error. I can reach other sites without problems. I´m also not using a VPN. Is the site online? Pinging synology.emby.media [67.205.150.221] with 32 bytes of data: Reply from 67.205.150.221: bytes=32 time=106ms TTL=50 Thanks, Nelson
FrostByte 5454 Posted July 3, 2021 Posted July 3, 2021 That looks like the old repository which isn't used anymore. Just download the appropriate spk from the below link and do a manual install Download Emby - Emby
NelsonSilva 1 Posted July 3, 2021 Author Posted July 3, 2021 Thank you, you are right. Can you tell me how are the updates done in Synology? Are they automatic or manual? Thanks, Nelson
FrostByte 5454 Posted July 3, 2021 Posted July 3, 2021 As of right now they are all manual. After the first manual install you will get update notifications in the dashboard, but that's about it. However, they are working with Synology to add the package to the official store. Once it's in the store it should update like any other store app. I haven't seen when they expect that to happen. 1 1
