chacawaca 109 Posted July 2, 2021 Posted July 2, 2021 I have a bug since 2-3 emby IOS version before that, that was fine. When i stream music to a airplay v1 device, volume keep reset to a default value between each song. IOS vers 2.0.8, server 4.6.4.0, song direct play no transcode. Tested EMBY output on phone, everything is fine tested Emby output to airplay v2 device, everything is fine tested Emby output to airplay v1 device, volume reset between each song tested Apple music to same airplay v1 device, everything is fine
chacawaca 109 Posted July 2, 2021 Author Posted July 2, 2021 Done more test, problem seem to be only ios 14.6, ( i dont have other 14.x to test), ios 12.XX work well with lasted version of emby
