Shenniko 7 Posted July 2, 2021 Posted July 2, 2021 Hi, so i want to re-build my linux server, which would mean a fresh install of Emby.. But i dont want Emby to go out and try and scan all the librarys, and try and find all the metadata etc.. So what folders/files do i need to backup/restore to make sure Emby doesnt try to do a full system scan? (as last time i done this, google drive blocked me for too many requests....) On Librarys Metadata Saves is set to NFO Save artwork into media folders is enabled Thanks Shenn
Shenniko 7 Posted July 2, 2021 Author Posted July 2, 2021 If i just take a copy of /var/lib/emby/ and /opt/emby-servers/ and when i've re-rinstalled, replace those folders/files with my copy would this work?
Happy2Play 9813 Posted July 2, 2021 Posted July 2, 2021 (edited) No need for Application path: /opt/emby-server as that is what you have already re-installed the server application folder. All you need to do is replace the Data path folder as it contains everything from your previous setup. Data path: /var/lib/emby Edited July 2, 2021 by Happy2Play 1
Shenniko 7 Posted July 17, 2021 Author Posted July 17, 2021 (edited) Hi @Luke, @Happy2Play So finally got round to looking at this.. I've wiped and re-built my server, now using docker-container for Emby, with rclone and SWAG... think i have everything setup correctly... How would i copy my backup to that location as now im using Docker, it cant find /var/lib/emby I've tried mapping it in the docker container to /Path/To/Backup/emby/config:/config but when i start the docker and goto URL its just asking me to install from fresh. Thanks Shenn Edited July 17, 2021 by Shenniko
Q-Droid 1011 Posted July 18, 2021 Posted July 18, 2021 Is "/Path/To/Backup/emby" a backup of "/var/lib/emby"? If so then I think your volume mapping for the container should be "/Path/To/Backup/emby":/config.
