USMC4345 1 Posted July 2, 2021 Posted July 2, 2021 I am having a problem getting my movies into the separate library even though I made one library for movies and another for TV shows. The movies seem to go into the Tv shows library when they are clearly in their own folder and named accordingly. I also can not identify them. Any suggestions?
Abobader 3485 Posted July 2, 2021 Posted July 2, 2021 Hello USMC4345, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
Solution seanbuff 1353 Posted July 2, 2021 Solution Posted July 2, 2021 Looks like you've inadvertently used the 'EMBY' root folder for your TV Shows (which has a subfolder of Movies also, hence why you see them there) Adjust your 'TV Shows' library path to be: C:\Users\<username>\Desktop\EMBY\TV Shows 1 1 1
seanbuff 1353 Posted July 2, 2021 Posted July 2, 2021 Be sure to run a full scan after you adjust the paths and you should be good
USMC4345 1 Posted July 2, 2021 Author Posted July 2, 2021 4 hours ago, seanbuff said: Looks like you've inadvertently used the 'EMBY' root folder for your TV Shows (which has a subfolder of Movies also, hence why you see them there) Adjust your 'TV Shows' library path to be: C:\Users\<username>\Desktop\EMBY\TV Shows Wow I knew it had to be something simple! Thank you so much! 1
