atomicmoon 152 Posted July 1, 2021 Posted July 1, 2021 Currently my Emby Live TV guide data only provides 6hrs of data. I've checked this against the program itself and it is pulling in around 14 days of guide data. Is there anything specific I need to apply to this link to have it pull in more than 6 hours of data at a time? http://SERVERIP:8089/devices/ANY/guide/xmltv If I manually refresh the guide data in Emby, it does update, but no more than 6hrs at a time.
Luke 42255 Posted July 1, 2021 Posted July 1, 2021 Hi, there is no limit being applied in Emby Server. I would check the guide data that is coming from the url that you've configured.
atomicmoon 152 Posted July 1, 2021 Author Posted July 1, 2021 After some more guerilla researching, I found the link needs a time suffix added to it http://SERVERIP:8089/devices/ANY/guide/xmltv?duration=604800 The, ?duration=604800 pulls in 604,800 seconds worth of guide info. Not sure why Emby doesn't grab everything in the link, but just happy to get to programs that weren't designed to work together, to work together. Thanks as always for replying on a subject that only partially contains Emby support! This is working like a complete dream come true!
Carlo 4561 Posted July 1, 2021 Posted July 1, 2021 Emby does process everything it gets. Adding that duration is telling Channels DVR how much data to send vs the default. Glad you got it figured out and working!
