YOUSSEFBOU 1 Posted July 1, 2021 Posted July 1, 2021 Bonjour, emby ne me montre pas de chaines après avoir intégré le fichier m3u malgré qu'il marche sur VLC. quelqu'un pourrai m'aider. j'ai vu beaucoup de tuto mais j'ai rien trouver sur mon problème.
YOUSSEFBOU 1 Posted July 1, 2021 Author Posted July 1, 2021 non j'ai utiliser VLC juste pour tester le fichier m3u et jai vu les chaine tv.ca a marcher ; mais sur emby il y a rien.
Carlo 4561 Posted July 1, 2021 Posted July 1, 2021 OK just checking because you posted in the MediaPortal section of the site. Do you get any channels showing up if you click the Guide tab? From the admin website if you click on Channels can you show us a screen shot of what shows up there?
Carlo 4561 Posted July 1, 2021 Posted July 1, 2021 (edited) Sorry, I meant this menu But I've got the feeling yours is empty which would likely mean Emby isn't able to read your m3u file. If you like you can PM your m3u file and I can test it for you. Edited July 1, 2021 by cayars
Carlo 4561 Posted July 2, 2021 Posted July 2, 2021 Hi, Click on my username then send me a direct message. Just drag your m3u file into the message or provide the download location for it.
YOUSSEFBOU 1 Posted July 2, 2021 Author Posted July 2, 2021 (edited) A Edited July 2, 2021 by YOUSSEFBOU
YOUSSEFBOU 1 Posted July 2, 2021 Author Posted July 2, 2021 juste une minute je change le fichier et je te l'envoi pour test. 1
YOUSSEFBOU 1 Posted July 2, 2021 Author Posted July 2, 2021 (edited) can you testet in not working for me. no chanel detected. Edited July 2, 2021 by YOUSSEFBOU
Carlo 4561 Posted July 3, 2021 Posted July 3, 2021 I sent you an email but the format after editing is all wrong now. You want to use a text editor that doesn't reformat or rewrite lines. Then you just highlight the channels you don't need and hit the delete key.
Carlo 4561 Posted July 3, 2021 Posted July 3, 2021 He re-edited the m3u file and I tested it and it now works on my system. However, he was trying to use schedules direct for EPG which is blocked so I suggested he replace that in PM as well.
