Tolerant 74 Posted August 26, 2014 Posted August 26, 2014 Isn't Auto Box Sets supposed to scan and add Collection ID's to XML's for each movie based on the collection they are in from TMDB.COM? For whatever reason, when I replace / upgrade / add movies to my database I have to manually go in and edit each XML file and add the collection ID myself. This is an extreamly tedious process and I thought the point of this addon was to automate the process. Am I missing something in the way this should work? Thanks. Updates from the web is turned on for MBS / MBC.
Luke 42254 Posted August 26, 2014 Posted August 26, 2014 It creates collections automatically using Collection Id's that are in your metadata.
Tolerant 74 Posted August 26, 2014 Author Posted August 26, 2014 Oh, well that explains it. I thought it was broken cause I had to keep editing all the xml's. Thanks for the response.
Tolerant 74 Posted August 26, 2014 Author Posted August 26, 2014 Ah, yep, 1.0.0.4 works to add the id's into the xml's. Thanks. Offtopic: Can't get a PS3 to see any files listed in the MediaBrowser that shows up, any ideas? http://mediabrowser.tv/community/index.php?/topic/9977-playstation-3/
Tolerant 74 Posted August 27, 2014 Author Posted August 27, 2014 Sure I am, the thing is when I go into a set and choose "Titles" and "Add", at that point I assumed it would add the ID's into each movie's XML but it doesn't seem to. I have to manually go in and edit them myself and add the ID ##### and save. I could have sworn I didn't used to have to do that.
ebr 16344 Posted August 27, 2014 Posted August 27, 2014 What version of the plug-in do you have? The most recent version (1.0.0.2+) actually will do that for you - but only the most recent one. That is the last functionality that I added to it.
ebr 16344 Posted August 27, 2014 Posted August 27, 2014 Can I see a server log when you add items to a collection that has a valid tmdb ID? Maybe something broke between the beta and release servers.
ebr 16344 Posted August 27, 2014 Posted August 27, 2014 Okay, never mind. It was a bug in the plug-in that didn't get caught by the testers. Please update and see if 1.0.0.4 works for you. Thanks for the report.
