winniewangyh 2 Posted June 29, 2021 Posted June 29, 2021 My cpu is Gold G5420. Emby has been using cpu transcoding after using hdr tone mapping function. If you don’t use this function, you can use gpu transcoding function normally.What is the problem?
Carlo 4561 Posted June 29, 2021 Posted June 29, 2021 That's a low end Pentium 2 core proc with Intel® UHD Graphics 610 graphics. It can likely do some transcoding but probably isn't up to the task for tone mapping. Is that what you're finding?
winniewangyh 2 Posted June 30, 2021 Author Posted June 30, 2021 13 hours ago, cayars said: 这是一款配备 Intel® UHD Graphics 610 显卡的低端 Pentium 2 核心处理器。 它可能会进行一些转码,但可能无法胜任色调映射的任务。 这是你要找的吗? After turning on tone mapping, I did not use gpu transcoding, but used cpu transcoding. At the same time, I am also using plex, which can use tone mapping very well.
Carlo 4561 Posted June 30, 2021 Posted June 30, 2021 Hi, can you post a screen shot or two of your current Transcoding menu options? Please change the first option to Advanced so we can see everything.
winniewangyh 2 Posted July 1, 2021 Author Posted July 1, 2021 22 hours ago, cayars said: Hi, can you post a screen shot or two of your current Transcoding menu options? Please change the first option to Advanced so we can see everything.
Carlo 4561 Posted July 1, 2021 Posted July 1, 2021 That's only a partial amount. There should be more configuration options on that page we need to see.
Luke 42243 Posted July 1, 2021 Posted July 1, 2021 5 hours ago, cayars said: That's only a partial amount. There should be more configuration options on that page we need to see. Which ones in particular do you need from him?
Carlo 4561 Posted July 1, 2021 Posted July 1, 2021 Throttling, sub extraction on the fly, tone map setting.
Luke 42243 Posted July 1, 2021 Posted July 1, 2021 On 6/29/2021 at 2:29 AM, winniewangyh said: My cpu is Gold G5420. Emby has been using cpu transcoding after using hdr tone mapping function. If you don’t use this function, you can use gpu transcoding function normally.What is the problem? Hi @winniewangyh can we please look at a specific example of this? Please attach the information requested here: Thanks.
winniewangyh 2 Posted July 3, 2021 Author Posted July 3, 2021 On 7/1/2021 at 11:20 PM, cayars said: Throttling, sub extraction on the fly, tone map setting. Are these all right?If not, please tell me where to get it
winniewangyh 2 Posted July 3, 2021 Author Posted July 3, 2021 On 7/2/2021 at 5:00 AM, Luke said: Hi @winniewangyh can we please look at a specific example of this? Please attach the information requested here: Thanks. I found Emby Server Logs,but I did not find WMC Logs logs.zip
Carlo 4561 Posted July 3, 2021 Posted July 3, 2021 Sorry can't really tell much from those screen shots since it's not in English. Instead can you upload the hardware detection log file? That should be more helpful.
winniewangyh 2 Posted July 3, 2021 Author Posted July 3, 2021 1 minute ago, cayars said: Sorry can't really tell much from those screen shots since it's not in English. Instead can you upload the hardware detection log file? That should be more helpful. Do you mean Emby Server Logs?
winniewangyh 2 Posted July 3, 2021 Author Posted July 3, 2021 Just now, cayars said: This one. hardware_detection-63760904258.txt
Luke 42243 Posted July 9, 2021 Posted July 9, 2021 @winniewangyh can you please attach an ffmpeg transcoding log example of this? Thanks.
winniewangyh 2 Posted July 11, 2021 Author Posted July 11, 2021 On 7/10/2021 at 12:40 AM, Luke said: @winniewangyh can you please attach an ffmpeg transcoding log example of this? Thanks. How can I get it?
Luke 42243 Posted July 11, 2021 Posted July 11, 2021 10 hours ago, winniewangyh said: How can I get it? Instructions can be found here: Thanks.
winniewangyh 2 Posted July 12, 2021 Author Posted July 12, 2021 17 hours ago, Luke said: Instructions can be found here: Thanks. I think I found some logs embyserver.txt ffmpeg-remux-4e62cc2a-1713-471b-b0dd-33e7f80b213d_1.txt ffmpeg-remux-c16b63c9-ddf2-47df-a84e-30998eef936b_1.txt ffmpeg-transcode-3e8c97dc-4fa6-401f-951a-2197d17c5420_1.txt ffmpeg-transcode-345219b1-9d6e-4d2d-b6cd-f4dd2511cd00_1.txt
Carlo 4561 Posted July 12, 2021 Posted July 12, 2021 One transcode looked like it was working but received a quit command. The other transcode errored out. @softworkz
Luke 42243 Posted July 12, 2021 Posted July 12, 2021 For the one that quit, I think that happened because the player probably aborted playback due to not receiving data quickly enough. You can see in the ffmpeg log it's not able to transcode quickly enough to be playable. That one was all done with software transcoding though based on your server settings, so that's not a big surprise. Try setting server transcoding settings back to default and see how that compares. Thanks.
winniewangyh 2 Posted July 13, 2021 Author Posted July 13, 2021 (edited) 18 hours ago, Luke said: For the one that quit, I think that happened because the player probably aborted playback due to not receiving data quickly enough. You can see in the ffmpeg log it's not able to transcode quickly enough to be playable. That one was all done with software transcoding though based on your server settings, so that's not a big surprise. Try setting server transcoding settings back to default and see how that compares. Thanks. I mean when I set the HDR tone mapping to only hardware acceleration, the transcoding calls cpu to handle the transcoding workffmpeg-transcode-da6a9c89-fd54-43fb-b070-23b6d4044130_1.txt Then I set the HDR tone mapping to automatic, and the transcoding call is also the cpu processing the transcoding work.ffmpeg-transcode-eb0b0727-f85a-484a-b41e-2c02fbe56df6_1.txt My GPU is capable of HDR tone mapping, but it is not used,In addition, my transcoding settings are all default values,So i don't know what went wrong Edited July 13, 2021 by winniewangyh
Carlo 4561 Posted July 13, 2021 Posted July 13, 2021 Hi could you try something for me. Install the Emby Diagnostics Plugin from the catalog and choose Extra-T for VAAPI tone mapping. You will need this plugin installed to try the Extra-T tone mapping options. Let us know if this makes any difference for you.
winniewangyh 2 Posted July 13, 2021 Author Posted July 13, 2021 9 minutes ago, cayars said: Hi could you try something for me. Install the Emby Diagnostics Plugin from the catalog and choose Extra-T for VAAPI tone mapping. You will need this plugin installed to try the Extra-T tone mapping options. Let us know if this makes any difference for you. I have installed this plugin, but I don't know how to choose Extra-T tone mapping options.
