FrostByte 5454 Posted July 9, 2021 Posted July 9, 2021 (edited) Install any file explorer/manager app on your Shield copy the apk to a thumb drive stick drive in Shield From Shield use file explorer to navigate to the apk on thumb drive Click/Install Edited July 9, 2021 by FrostByte 2
Carlo 4561 Posted July 9, 2021 Posted July 9, 2021 Or use a network share instead of thumb drive which is how I do it. Either way works fine.
crusher11 1143 Posted July 9, 2021 Author Posted July 9, 2021 The last time I sideloaded an app, it was inaccessible in my apps menu and I have not to this day figured out how to open it, so...disinclined to go that route. However, I searched for Emby on the play store and it gave me an update option, so I'm now on 2.0.30, which is at least closer.
Carlo 4561 Posted July 9, 2021 Posted July 9, 2021 If you sideload the app it will replace your current Emby app so there should be no looking around for it. The apps all show the same way regardless of how they were loaded (store or sideload). 1
FrostByte 5454 Posted July 9, 2021 Posted July 9, 2021 1 hour ago, cayars said: Or use a network share instead of thumb drive which is how I do it. Either way works fine. Me too, I was just trying to apply KISS 1
vdatanet 1619 Posted July 9, 2021 Posted July 9, 2021 I remember someone saying that sideloading was so easy that even @crusher11 could do it, that folk was wrong. 4
vdatanet 1619 Posted July 24, 2021 Posted July 24, 2021 On 7/8/2021 at 4:35 PM, ebr said: The double % thing is a sticky issue but I think I've worked around it. Thanks. Fixed in 2.0.32. Thanks! 2
