Carlo 4561 Posted June 29, 2021 Posted June 29, 2021 Without touching it I get the same thing as you @Happy2Play
Happy2Play 9802 Posted June 29, 2021 Posted June 29, 2021 @Bigmack3000since cayars did not have a issue with the file on his Synology, I am guess as database issue. But a server log may provide more info if there are errors. Do you get the same result with this tagged track? Will delete after testing. 13 Lyrics To Go {VR}-tagged.m4a
Luke 42202 Posted June 30, 2021 Posted June 30, 2021 Quote But even after completely refreshing the album, the artist, and then the whole library in emby, the genre and year still don't pop up. How exactly did you try to do that?
Bigmack3000 108 Posted June 30, 2021 Author Posted June 30, 2021 3 hours ago, Luke said: How exactly did you try to do that? The "Refresh Metadata" option then "replace all metadata". Finally, I removed the album from the library, refreshed. Then added it back in, and now it pops up with the genre. So I'm not sure what the initial problem was, but it appears to be solved for now. I'll see if it happens to more files. Thanks everyone.
