Luke 42244 Posted August 16, 2021 Posted August 16, 2021 38 minutes ago, luundblad said: i mean i removed "emby_pkg" OK. Did you try what I suggested?
luundblad 6 Posted August 16, 2021 Posted August 16, 2021 1 minute ago, Luke said: OK. Did you try what I suggested? Yes, even if i uninstall emby from the package center emby is till running in the "background" Even if i removed all files thru ssh under /var/packaged/EmbyServer & /volume3/@appstore/EmbyServer
Luke 42244 Posted August 16, 2021 Posted August 16, 2021 2 minutes ago, luundblad said: Yes, even if i uninstall emby from the package center emby is till running in the "background" Even if i removed all files thru ssh under /var/packaged/EmbyServer & /volume3/@appstore/EmbyServer Where exactly does it say that it's running in the background? Try uninstalling and then rebooting the NAS.
Yog-Sothoth 2 Posted August 20, 2021 Posted August 20, 2021 @Luke Hi, I run on DSM 7 and EMBY 4.7.0.3. I view you make a new beta package 4.7.0.7 and I can't install it. I received: this package requires dsm 7.0-40000 or older Why??? Regards
kaj 339 Posted August 20, 2021 Posted August 20, 2021 4 hours ago, Yog-Sothoth said: @Luke Hi, I run on DSM 7 and EMBY 4.7.0.3. I view you make a new beta package 4.7.0.7 and I can't install it. I received: this package requires dsm 7.0-40000 or older Why??? Regards You are downloading the wrong package, for DSM 6. Make sure the file you download has Synology7 in the name 1
Yog-Sothoth 2 Posted August 20, 2021 Posted August 20, 2021 @kaj Right, I didn't view that. Thank you. Regards, 1
Mick_K 7 Posted August 20, 2021 Posted August 20, 2021 Wow, given all the issues reported with the migration to DSM 7, I might hang off doing it for a while until it gets as simple as updating DSM and downloading an Emby package.. I don't fancy having to redo all of emby if I stuff it up (very likely with having to do putty etc.). It's working great now with DSM 6.2.4.25556 and Emby 4.6.4.0 and as the saying goes, "if it ain't broken..." Kudos to everyone who's managed to update.
Carlo 4561 Posted August 20, 2021 Posted August 20, 2021 It's actually a pretty simple process if you follow the instructions. If/when you're ready to upgrade we can always give you a hand remotely if needed, if that would make you feel more comfortable about the migration.
Mick_K 7 Posted August 22, 2021 Posted August 22, 2021 I thought I'd try given the step-by-step instructions..... little did I know that I'd be copying my ENTIRE library TWICE. 21 hrs and it's still "upgrading"... I hope to G, it doesn't come up with a "out of space" error
FrostByte 5454 Posted August 22, 2021 Posted August 22, 2021 (edited) 1 hour ago, Mick_K said: I thought I'd try given the step-by-step instructions..... little did I know that I'd be copying my ENTIRE library TWICE. 21 hrs and it's still "upgrading"... I hope to G, it doesn't come up with a "out of space" error You shouldn't be copying libraries, just Emby configuration files, etc. Unless you had your libraries in the same folder as Emby server I guess. And why twice? There is only one copy command in putty The whole process should take minutes, not days Edited August 22, 2021 by FrostByte
Mick_K 7 Posted August 22, 2021 Posted August 22, 2021 50 minutes ago, FrostByte said: You shouldn't be copying libraries, just Emby configuration files, etc. Unless you had your libraries in the same folder as Emby server I guess. And why twice? There is only one copy command in putty The whole process should take minutes, not days Step 9 cp -rv /volume1/Emby/* /volume1/@appdata/EmbyServer Final Final Step cp -rv /volume1/Emby/* /volume1/@appdata/EmbyServer And yes, EVERYTHING is located in the same folder as Emby Server under "data"
Mick_K 7 Posted August 22, 2021 Posted August 22, 2021 Ok finally finished. Everything seems to be working but do I now have duplicate Movies folder or is one a symbolic link to another? Folder: /var/packages/EmbyServer/var/data/video/Movies (Optional) Shared network folder: \\192.168.0.24\emby\data\video\Movies
Carlo 4561 Posted August 22, 2021 Posted August 22, 2021 7 hours ago, Mick_K said: Step 9 cp -rv /volume1/Emby/* /volume1/@appdata/EmbyServer Final Final Step cp -rv /volume1/Emby/* /volume1/@appdata/EmbyServer And yes, EVERYTHING is located in the same folder as Emby Server under "data" This copy step is only given once in the directions that I can see. Where do you see it listed twice?
Carlo 4561 Posted August 22, 2021 Posted August 22, 2021 5 hours ago, Mick_K said: Ok finally finished. Everything seems to be working but do I now have duplicate Movies folder or is one a symbolic link to another? Folder: /var/packages/EmbyServer/var/data/video/Movies (Optional) Shared network folder: \\192.168.0.24\emby\data\video\Movies That is not a good place to have media. My suggestion to you would be to create a shared folder specific for media. On my Synology this is call "Media". Under Media share I have my different libs. So for example: /Media/Movies /Media/TV Shows /Media/Music /Media/Home Videos etc Having you media setup like this also allows use of File Station as well as mounting this share in Windows for easy access to it. 1
FrostByte 5454 Posted August 22, 2021 Posted August 22, 2021 1 hour ago, cayars said: This copy step is only given once in the directions that I can see. Where do you see it listed twice? @cayarsThe other user instructions with the pictures is different and repeats the copy command in the Final step. That probably could be redone to match yours with the pictures. No need to do that twice if done at the right point So, since Mick_K has his media there also it copied everything twice . 1
Mick_K 7 Posted August 24, 2021 Posted August 24, 2021 On 8/22/2021 at 8:52 PM, cayars said: That is not a good place to have media. My suggestion to you would be to create a shared folder specific for media. On my Synology this is call "Media". Under Media share I have my different libs. So for example: /Media/Movies /Media/TV Shows /Media/Music /Media/Home Videos etc Having you media setup like this also allows use of File Station as well as mounting this share in Windows for easy access to it. I had Emby installed on a share (/volume1/emby/) to do precisely that (mount the share in Windows for easy access to files). It made sense at the time to put media in the data folder of Emby Server. Since Emby is now no longer installed on a share, my media is as you suggested (located on a share that Windows has access to). I have also deleted the media duplicates from /volume1/@appdata/EmbyServer which were copied over as part of the updating process. The only problem now is that I don't have direct access (like I did with the share) to the Emby Server files without having to use PuTTY or the like.
Mick_K 7 Posted August 24, 2021 Posted August 24, 2021 On 8/22/2021 at 10:14 PM, FrostByte said: So, since Mick_K has his media there also it copied everything twice . Correct. I have since moved the media library to its own share so future Emby/DSM updates don't effect it as @cayars suggested. 1
FrostByte 5454 Posted August 24, 2021 Posted August 24, 2021 My point being though that there was no need to do that step twice. @cayars own instructions don't have that step twice. So he should remove that link and add graphics to his own instructions if he wishes 1
Carlo 4561 Posted August 24, 2021 Posted August 24, 2021 I edited the op post of the migration instructions to remove the link to the pictured instructions as they have a few extra steps not needed and I'm fielding PMs on it. The step by step instructions and video should be fine. 1
Gamble 2 Posted September 9, 2021 Posted September 9, 2021 Hi Help and advise needed thank you. I have a ds220j and recently blindly updated dsm to version 7, then found Emby did not work. I subsequently deleted the existing Emby with a view to installing the synology version 7. When I try to manually install from package centre using the downloaded file "emby-server-synology7_4.6.4.0_x86_64", I get the message "This package is not supported on the platform of Synology NAS or is incompatible with the current DSM version." . I have tried other versions with same result. I have read it is not possible to go back to a previous version of DSM , therefore would you advise a complete reset back to factory for the ds220j or is there a step by step guide to reinstate emby. Thank you
Carlo 4561 Posted September 9, 2021 Posted September 9, 2021 Hi, pretty sure the DS220j is an ARM8 not X86/64 package. Can you download and install that version. Did you delete /volume1/Emby? 1
FrostByte 5454 Posted September 10, 2021 Posted September 10, 2021 Here's a list of processors and chips showing the RTD1296 is indeed ARM8 Architecture per Synology model · SynoCommunity/spksrc Wiki · GitHub 1
Gamble 2 Posted September 10, 2021 Posted September 10, 2021 Thanks will try the arm8 when I get chance, will let you know the outcome. 1
Gamble 2 Posted September 11, 2021 Posted September 11, 2021 Hi Just to let you know my Emby up and running again, the Arm8 software installed with no problems on the ds220J. Many thanks for the support. However I did struggle with adding the library details for a while when I spotted the solution in one of your postings which was to make sure read/write for Emby was enabled in "System Internal User". It was then just a matter of adding the library paths for the metadata to be collected. I can now settle an watch a movie. Thank you 1
Carlo 4561 Posted September 11, 2021 Posted September 11, 2021 Thanks for the update. Glad you got it working!
