Carlo 4561 Posted June 30, 2021 Posted June 30, 2021 (edited) 2 minutes ago, richardyu301 said: Thank you. As I have already installed Emby again, do I need to uninstall/clean cache/cp/reinstall again? Or can I simply stop Emby, cp and restart Emby? Try starting from the copy line and see what happens. As long as you don't delete/modify your original DSM 6 install you can retry this. Edited June 30, 2021 by cayars
Guest Posted June 30, 2021 Posted June 30, 2021 4 minutes ago, cayars said: Yes there is a space between them cp -r /volume1/Emby /volume1/@appdata/EmbyServer no, its about the /* within source folder
Carlo 4561 Posted June 30, 2021 Posted June 30, 2021 Thanks, I didn't write those instructions but copied them from another user posting in the forum that others said worked. I'll setup a DSM 6 VM, install Emby on it and then perform the upgrade following all directions to verify. Thanks a lot!
dlnqt 1 Posted June 30, 2021 Posted June 30, 2021 On 6/26/2021 at 1:26 AM, cayars said: The thread I linked to has these instructions in it. Instructions for upgrade from dsm6 to dsm7 (beta!!!) with keeping library: - make sure, you have dsm6 and dsm7 Emby (beta) package for same version. At post creation it was: 4.6.0.35 Link for lastest versions from first post: https://github.com/MediaBrowser/Emby.Releases/releases - update Emby to 4.6.0.35 dsm6 package - start Emby and check if update went good - stop Emby - goto Emby share clean cache, logs, transcoding-temp (with filestation) - uninstall Emby - update DSM to v7 - install Emby 4.6.0.35 (dsm7 version) - stop Emby - remove emby_pkg user and video group - enable ssh in Synology settings - connect with Putty to Synology, login with admin user and get root rights with: sudo -i - copy files from old Emby share to new data location: cp -r /volume1/Emby /volume1/@appdata/EmbyServer - adjust owner from copied files: chown -R emby:emby /volume1/@appdata/EmbyServer - close putty - add emby user and emby group to your shared media folder in Synology - start Emby Emby should work fine now with old library/users. As last step, you can remove the old Emby share. I'm confused on the following part? What Am I supposed to share with? I see the following folders within the Emby folder........Cache, logs and transcoding-temp folders....what should I do with them....? - goto Emby share clean cache, logs, transcoding-temp (with filestation)
richardyu301 3 Posted June 30, 2021 Posted June 30, 2021 1 hour ago, alex8127378 said: no, its about the /* within source folder I have tried with below command (without uninstall/reinstall again). I was asked for password and then can see the view history / playlists / favorites, etc. cp -r /volume1/Emby/* /volume1/@appdata/EmbyServer However, all the libraries under My Media are now missing. Anything I have missed?
Carlo 4561 Posted June 30, 2021 Posted June 30, 2021 I'm running through the previous instructions and making adjustments as needed on Synology VM at present. I'll post revised instructions as soon as I'm done.
richardyu301 3 Posted June 30, 2021 Posted June 30, 2021 (edited) 8 minutes ago, richardyu301 said: I have tried with below command (without uninstall/reinstall again). I was asked for password and then can see the view history / playlists / favorites, etc. cp -r /volume1/Emby/* /volume1/@appdata/EmbyServer However, all the libraries under My Media are now missing. Anything I have missed? Sorry after waiting a while, the libraries appear. However, for every library there are two copies. When I deleted one of them, the other one is removed too. Edited June 30, 2021 by richardyu301
Guest Posted June 30, 2021 Posted June 30, 2021 42 minutes ago, dlnqt said: I'm confused on the following part? What Am I supposed to share with? I see the following folders within the Emby folder........Cache, logs and transcoding-temp folders....what should I do with them....? - goto Emby share clean cache, logs, transcoding-temp (with filestation) - goto the Shared-Folder named Emby - delete content of following folders: Cache, Logs and Transcoding-temp
Carlo 4561 Posted June 30, 2021 Posted June 30, 2021 (edited) Attached is a quick video I made of upgrading DSM 6 to DSM 7 with Emby Updates. I had instructions off to the left but the screen capture program only recorded the browser. So you won't see me downloading or PUTTY/SSH commands but everything done in browser is recorded. I converted this to MKV/H.265 to make it small enough to upload. Let me know if this helps or if you think I missed any crucial steps. DMS7 Upgrade for Emby.mkv Instructions used were: Download and have ready DSM 7 package for update. https://www.synology.com/en-us/DSM70 (I will be downloading both a virtualDSM 7 & for 920+) Download and have ready Emby Server 4.6.3 for both DSM 6 & DSM 7 https://emby.media/download.html - update Emby Server to 4.6.3 (or latest release) - restart Emby Server and verify your on 4.6.3 - uninstall Emby - update DSM to v7 - install Emby 4.6.3 (or same version that was running above (dsm7 version) - stop Emby - remove emby_pkg user and video group - enable admin account if needed - give read/write permissions to your login ID and add Emby - enable ssh in Synology settings (Terminal & SNMP menu) Not shown in video: - connect with Putty to Synology, login with admin user and get root rights with: sudo -i - copy files from old Emby share to new data location: cp -r /volume1/Emby/* /volume1/@appdata/EmbyServer - adjust owner from copied files: chown -R emby:emby /volume1/@appdata/EmbyServer - close putty Shown again in video: - From Control Panel go to Shared Folder and edit each share that is used by Emby Server. Click the share, then EDIT, go to permission tab, select internal system user from drop down, grant emby user read/write access. - add emby user and emby group to your shared media folder in Synology - start Emby Edited June 30, 2021 by cayars 1 4
Banshees 0 Posted June 30, 2021 Posted June 30, 2021 Hmm... package not working from Emby The version of DSM i download from Synology for my DS418 : 7.0-41890 The error message : This package requires DSM 7.0-40000(update o) or older. So... no Emby running anymore on my NAS.. damn ! And i'm a Emby premier user !
dlnqt 1 Posted June 30, 2021 Posted June 30, 2021 When I go and hit the run and then open on the Emby icon, it then goes back to run after a few seconds...I am unable to enter Emby...
Carlo 4561 Posted June 30, 2021 Posted June 30, 2021 1 hour ago, Banshees said: Hmm... package not working from Emby The version of DSM i download from Synology for my DS418 : 7.0-41890 The error message : This package requires DSM 7.0-40000(update o) or older. So... no Emby running anymore on my NAS.. damn ! And i'm a Emby premier user ! That file name looks like the DSM 6 version of Emby Server, not the DSM 7 version. Please make sure you download the DSM 7 version. 1
Carlo 4561 Posted June 30, 2021 Posted June 30, 2021 35 minutes ago, dlnqt said: When I go and hit the run and then open on the Emby icon, it then goes back to run after a few seconds...I am unable to enter Emby... We need more context of what steps you've done.
dlnqt 1 Posted June 30, 2021 Posted June 30, 2021 3 minutes ago, cayars said: We need more context of what steps you've done. All of them. I got the very end when it was time to open Emby up. Everything seemed to have worked besides actually opening the app 3 minutes ago, cayars said: We need more context of what steps you've done.
Carlo 4561 Posted June 30, 2021 Posted June 30, 2021 Try watching the video I linked to above to see if you did anything different.
sdasmith 1 Posted July 1, 2021 Posted July 1, 2021 Can I not just move my media to an external drive update DSM 6 to DSM 7 on my 918+ Reformat the Synology Raid drives Move my media back and have Emby index again?
sdasmith 1 Posted July 1, 2021 Posted July 1, 2021 (edited) Will there be a future Emby update to make a DSM 7 install more automatic? Upgrade to DSM7 and then just update Emby. Edited July 1, 2021 by sdasmith
sybold 0 Posted July 1, 2021 Posted July 1, 2021 insted of cp -r /volume1/Emby/* /volume1/@appdata/EmbyServer i used this mv -R /volume1/@appdata/EmbyServer /volume1/@appdata/EmbyServerbackup mv -R /volume1/Emby /volume1/@appdata/EmbyServer
Guest Posted July 1, 2021 Posted July 1, 2021 (edited) @sybold yes, this also works in the end. but this way, you create a backup of the new (unused) emby-files instead of the emby-files of your old installation. therefore i would recommend using the copy-cmd already posted: in case anything goes wrong, you still have a copy of your emby-config. and if everything works, you can just delete the old emby-share. Edited July 1, 2021 by alex8127378
unisoft 355 Posted July 1, 2021 Posted July 1, 2021 (edited) On 30/06/2021 at 17:50, cayars said: Attached is a quick video I made of upgrading DSM 6 to DSM 7 with Emby Updates. I had instructions off to the left but the screen capture program only recorded the browser. So you won't see me downloading or PUTTY/SSH commands but everything done in browser is recorded. I converted this to MKV/H.265 to make it small enough to upload. Let me know if this helps or if you think I missed any crucial steps. DMS7 Upgrade for Emby.mkv 21.57 MB · 22 downloads Instructions used were: Download and have ready DSM 7 package for update. https://www.synology.com/en-us/DSM70 (I will be downloading both a virtualDSM 7 & for 920+) Download and have ready Emby Server 4.6.3 for both DSM 6 & DSM 7 https://emby.media/download.html - update Emby Server to 4.6.3 (or latest release) - restart Emby Server and verify your on 4.6.3 - uninstall Emby - update DSM to v7 - install Emby 4.6.3 (or same version that was running above (dsm7 version) - stop Emby - remove emby_pkg user and video group - enable admin account if needed - give read/write permissions to your login ID and add Emby - enable ssh in Synology settings (Terminal & SNMP menu) Not shown in video: - connect with Putty to Synology, login with admin user and get root rights with: sudo -i - copy files from old Emby share to new data location: cp -r /volume1/Emby/* /volume1/@appdata/EmbyServer - adjust owner from copied files: chown -R emby:emby /volume1/@appdata/EmbyServer - close putty Shown again in video: - From Control Panel go to Shared Folder and edit each share that is used by Emby Server. Click the share, then EDIT, go to permission tab, select internal system user from drop down, grant emby user read/write access. - add emby user and emby group to your shared media folder in Synology - start Emby Brilliant guide. THIS NEEDS TO BE A STICKY AT TOP OF SYNOLOGY SECTION SO PEOPLE DON'T WASTE HOURS! External access by nginx reverse proxy all kept too after doing the instructions. I used WinSCP app (free) to copy the files from old Emby to @appdata/EmbyServer and then run the owner permissions change command line from the command prompt icon in WinSCP. I only give Emby internal system user READ on my Multimedia share though where my media libraries are and not READ/WRITE (I still use XML metadata not NFO in there) Now to delete the old Emby area that Emby has no access to, and has started successfully using new area. THANK YOU FOR THIS GUIDE 'CAYARS', MUCH APPRECIATED.... Edited July 2, 2021 by unisoft 1 2
mcwn2021 2 Posted July 2, 2021 Posted July 2, 2021 Thank you for the step by step and video cayers. Indeed a pin for this guide would be good. I have just completed the DSM 6 to 7 update and used your guide for Emby. All went well, I was concerned and had originally planned to leave the DSM upgrade alone for a couple of months. I took the plunge this afternoon after testing the upgrade on a virtual dsm setup. One thing I would say is to add a note mentioning that uninstalling emby (whilst in DSM6) will not erase your config settings as I thought may be the case. After testing in virtual DSM was happy to proceed. Happy to also report all my virtual machines are intact. (I did backup all my data first!) Thanks again. 1
unisoft 355 Posted July 2, 2021 Posted July 2, 2021 (edited) 2 hours ago, mcwn2021 said: Thank you for the step by step and video cayers. Indeed a pin for this guide would be good. I have just completed the DSM 6 to 7 update and used your guide for Emby. All went well, I was concerned and had originally planned to leave the DSM upgrade alone for a couple of months. I took the plunge this afternoon after testing the upgrade on a virtual dsm setup. One thing I would say is to add a note mentioning that uninstalling emby (whilst in DSM6) will not erase your config settings as I thought may be the case. After testing in virtual DSM was happy to proceed. Happy to also report all my virtual machines are intact. (I did backup all my data first!) Thanks again. Yes it kept my Emby metadata, fonts, config folders etc. after I uninstalled Emby 4.6.3 (for DSM 6.x). Just copied to new location after install and set ownership as described in cayars guide above. Edited July 2, 2021 by unisoft
Carlo 4561 Posted July 2, 2021 Posted July 2, 2021 Glad this worked for you guys. Did either of you have to differ at all from the instructions?
Ekomax 14 Posted July 2, 2021 Posted July 2, 2021 @cayars Thanks for your video and tutorial. Upgrading/Migration to DSM 7 went without problems. I would suggest you make this public. Thanks best regards Ekomax 1
Dedone 17 Posted July 2, 2021 Posted July 2, 2021 On 6/30/2021 at 6:50 PM, cayars said: Attached is a quick video I made of upgrading DSM 6 to DSM 7 with Emby Updates. I had instructions off to the left but the screen capture program only recorded the browser. So you won't see me downloading or PUTTY/SSH commands but everything done in browser is recorded. I converted this to MKV/H.265 to make it small enough to upload. Let me know if this helps or if you think I missed any crucial steps. DMS7 Upgrade for Emby.mkv 21.57 MB · 48 downloads Instructions used were: Download and have ready DSM 7 package for update. https://www.synology.com/en-us/DSM70 (I will be downloading both a virtualDSM 7 & for 920+) Download and have ready Emby Server 4.6.3 for both DSM 6 & DSM 7 https://emby.media/download.html - update Emby Server to 4.6.3 (or latest release) - restart Emby Server and verify your on 4.6.3 - uninstall Emby - update DSM to v7 - install Emby 4.6.3 (or same version that was running above (dsm7 version) - stop Emby - remove emby_pkg user and video group - enable admin account if needed - give read/write permissions to your login ID and add Emby - enable ssh in Synology settings (Terminal & SNMP menu) Not shown in video: - connect with Putty to Synology, login with admin user and get root rights with: sudo -i - copy files from old Emby share to new data location: cp -r /volume1/Emby/* /volume1/@appdata/EmbyServer - adjust owner from copied files: chown -R emby:emby /volume1/@appdata/EmbyServer - close putty Shown again in video: - From Control Panel go to Shared Folder and edit each share that is used by Emby Server. Click the share, then EDIT, go to permission tab, select internal system user from drop down, grant emby user read/write access. - add emby user and emby group to your shared media folder in Synology - start Emby Done!!!! i've take the courage and i'll make it. Everything seems ok at the moment. Really thanks cayars for your fantastic guide!!!!!!! 1
