Are chars "[" and "]" reserved for some purpose?
Go to solution Solved by jordy,
Hi,
I have some videos with names in the format "Event[Date-People]". When I import the videos into MBS, only the Event names are kept, the content in "[" and "]" are not stored in MBS.
Is it because "[" and "]" are reserved and I cannot use them in file names?
  • Solution
I believe that anything inside square brackets is ignored. Kinda like a way for you to identify individual folders or items without it affecting the finished result.
  • Like 1
Redshirt
That's correct. You can use soft braces instead though.
AdrianW
Are they something like Silky Suspenders?  :P
Is there any document about the naming rules where I can see something like this?
Thanks!
All official documents are in the Knowledge base  You might find something in there.
