rbjtech 5344 Posted June 25, 2021 Posted June 25, 2021 Just now, JustEric78 said: When you go into the mount section of Shield and find your server, do you just click on it and add your service account credentials and boom it works or was there more to it then that? Exactly this - I added the server, it then asked for credentials and boom - shares were added. From memory, it took a little while for the mounts to become 'available' on the shield - maybe 5-10 minutes, but once done - they were all listed on the shield - no further action necessary.
JustEric78 24 Posted June 25, 2021 Author Posted June 25, 2021 7 minutes ago, rbjtech said: Exactly this - I added the server, it then asked for credentials and boom - shares were added. From memory, it took a little while for the mounts to become 'available' on the shield - maybe 5-10 minutes, but once done - they were all listed on the shield - no further action necessary. Okay, thank you I will keep playing with this then.
ebr 16338 Posted June 25, 2021 Posted June 25, 2021 4 hours ago, JustEric78 said: The guest account on the server is definitely needed providing anonymous access to the shares. I tried putting permissions back the way they were and reconnected the Shield with credentials and it broke the file > direct play. Again - the simplest option is to just un-check the setting to use the direct file path. In 99% of cases, this is not going to buy you anything except for these headaches of access you are dealing with now. 1
