ng4ever 40 Posted June 23, 2021 Posted June 23, 2021 This is on my Synology DS-220+ I can't figure out why. Seems mainly when the movie starts playing yes it is direct streaming no transcoding. Here is the difference Plex 7 to 14% Emby 20 to 25% Maybe I am wrong though.
Solution Luke 42237 Posted June 23, 2021 Solution Posted June 23, 2021 Hi, plex splits their server into multiple processes whereas emby does not, so you have to make sure to add up all of the usage of all of the processes. 3
ng4ever 40 Posted June 23, 2021 Author Posted June 23, 2021 Just now, Luke said: Hi, plex splits their server into multiple processes whereas emby does not, so you have to make sure to add up all of the usage of all of the processes. Makes sense thanks! Is Emby 32 bit or 64 bit? What about Plex ?
Luke 42237 Posted June 23, 2021 Posted June 23, 2021 6 minutes ago, ng4ever said: Is Emby 32 bit or 64 bit? Our packages for Synology match the device architecture. If your device is 64-bit or arm64 or x86 or armv7, then our Synology package matches that.
ng4ever 40 Posted June 23, 2021 Author Posted June 23, 2021 1 minute ago, Luke said: Our packages for Synology match the device architecture. If your device is 64-bit or arm64 or x86 or armv7, then our Synology package matches that. Ok Thanks. Do you have any idea why Plex splits their server into multiple processes ? Does it really help any ?
Luke 42237 Posted June 23, 2021 Posted June 23, 2021 Probably because they want to keep certain things independent of each other. There are tradeoffs to consider either way. 1 1
