Dreakon13 143 Posted June 23, 2021 Posted June 23, 2021 (edited) Hi, when I select multiple albums (in this case these are singles with only one song per "album") and click Play, or Add to Play Queue, it only seems to play/add the first song. Example: You can see it only added Collapsing, the first selected of the four. Now if I select the other three again and attempt to add to the play queue: You can see it only added Heartbeat Failing (the first of the three selected). At this point I don't really have much of a choice but to add each individually, kinda defeating the purpose of multi-select. I think the multi-select is a newer feature so I'm sure there are kinks to work out. Just wanted to report what I was seeing. Thanks! Edited June 23, 2021 by Dreakon13
Carlo 4561 Posted June 23, 2021 Posted June 23, 2021 @Luke I can confirm the above happens 4.7.0.3 for both the initial and add to queue functionality. 2
Happy2Play 9811 Posted June 23, 2021 Posted June 23, 2021 Yes only the first album items are play when multi-selected and only the first multi-selected album is added to the queue when adding. 1
