PBearSFO 1 Posted June 23, 2021 Posted June 23, 2021 All of a sudden, a while back, one of my libraries ("Movies") stopped auto-generating (and auto-updating) its four-panel thumbnail and just started showing a single photo for that library, like so: It displays the same way on my Home page now. I tried using Edit Images to simply delete the single picture file (update with no file chosen) for the Movies library, hoping it would start automatically regenerating itself in a day or two but it just stays empty (the thumbnail remains blank). If I choose a specific picture file for the Movies library, then that file "sticks" (as in the included screenshot) -- the Movies library thumbnail is never updated again or changed back into an auto-generated, four-picture panel. How can this be fixed? Also, how can I DELETE a library? There is no delete option on any drop-down menu I can find under Settings/Libraries. (I originally checked the option to auto-generate Collections, wound up with one measly Collection, then changed my mind and turned off the option to auto-generate Collections -- but now I cannot delete the Collections library; it just sits there mocking me!) Regards.
Abobader 3485 Posted June 23, 2021 Posted June 23, 2021 Hello PBearSFO, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
Carlo 4561 Posted June 23, 2021 Posted June 23, 2021 Hi, please upload your latest server log so we can take a look at this for you. To delete a library you need to be logged in as an admin. Then just hover over the library, choose the 3 dot menu and choose the remove option.
GrimReaper 4861 Posted June 23, 2021 Posted June 23, 2021 Just now, cayars said: To delete a library you need to be logged in as an admin. Then just hover over the library, choose the 3 dot menu and choose the remove option. There ain't Delete option for Collections library. He can only "hide" it by restricting Access in User>Access tab. 1
PBearSFO 1 Posted June 23, 2021 Author Posted June 23, 2021 Is this the log file? (I was expecting something with a "log" extension.) embyserver.txt
PBearSFO 1 Posted June 23, 2021 Author Posted June 23, 2021 3 minutes ago, GrimReaper76 said: There ain't Delete option for Collections library. He can only "hide" it by restricting Access in User>Access tab. Well, that was the impression I got -- which seems insufficiently thought out . I've already hidden the Collections library (it doesn't show up in Home any longer) but I would kindly like to get rid of it altogether. That should certainly be an administrator's right, no? Same for any other libraries I may have created or might create in the future. Sigh.
ebr 16309 Posted June 23, 2021 Posted June 23, 2021 6 minutes ago, PBearSFO said: Same for any other libraries I may have created or might create in the future Hi. You can delete any libraries you create. The "Collections" library is not one of those, however. It is a virtual library created by the system.
Luke 42202 Posted June 23, 2021 Posted June 23, 2021 2 hours ago, PBearSFO said: Is this the log file? (I was expecting something with a "log" extension.) embyserver.txt 126.07 kB · 0 downloads Hi, did you run a library scan during the time of this log?
Happy2Play 9802 Posted June 23, 2021 Posted June 23, 2021 Do you have any loose images in the root of the three folder attached to Movies library? If provider Collections are not populating, you will need to Refresh Metadata on your media again. You can test by Refreshing a couple items that belong to the same collection.
PBearSFO 1 Posted June 23, 2021 Author Posted June 23, 2021 10 minutes ago, Luke said: Hi, did you run a library scan during the time of this log? No.
PBearSFO 1 Posted June 23, 2021 Author Posted June 23, 2021 6 minutes ago, Happy2Play said: Do you have any loose images in the root of the three folder attached to Movies library? If provider Collections are not populating, you will need to Refresh Metadata on your media again. You can test by Refreshing a couple items that belong to the same collection. Yes, one in each of the three. They weren't there before this problem started happening. I only put a different poster.jpg folder in each of those locations to try to FIX this problem, after it started giving me a single-picture thumbnail, then changed to giving me a blank thumbnail for the Movies library. (I am talking about Libraries here, not Collections, by the way.)
Happy2Play 9802 Posted June 23, 2021 Posted June 23, 2021 6 minutes ago, PBearSFO said: Yes, one in each of the three. They weren't there before this problem started happening. I only put a different poster.jpg folder in each of those locations to try to FIX this problem, after it started giving me a single-picture thumbnail, then changed to giving me a blank thumbnail for the Movies library. (I am talking about Libraries here, not Collections, by the way.) Emby will use parent folder images so dynamic image will not be created. Remove those loose images, and select edit image on the Movie library and delete the image then do a library scan. If dynamic image is not created then post the server log. But this should work as I just tested this and folder level image was used on Library. 1
Luke 42202 Posted June 23, 2021 Posted June 23, 2021 30 minutes ago, PBearSFO said: Yes, one in each of the three. They weren't there before this problem started happening. I only put a different poster.jpg folder in each of those locations to try to FIX this problem, after it started giving me a single-picture thumbnail, then changed to giving me a blank thumbnail for the Movies library. (I am talking about Libraries here, not Collections, by the way.) Well as soon as you customize it, it's not going to auto-generate one anymore since it will just use the one you specifically chose.
PBearSFO 1 Posted June 23, 2021 Author Posted June 23, 2021 1 hour ago, Happy2Play said: Emby will use parent folder images so dynamic image will not be created. Remove those loose images, and select edit image on the Movie library and delete the image then do a library scan. If dynamic image is not created then post the server log. But this should work as I just tested this and folder level image was used on Library. Well, that was easy. Thanks very much. 1
