Danimontes 11 Posted June 22, 2021 Posted June 22, 2021 Hola de nuevo, De verdad que es fantástico un foro como éste. Os agradezco toda la ayuda que nos prestáis, de verdad. Fuera peloteo, tengo una cuestión técnica: He adquirido un disco duro externo de 6TB y tenía en un principio la intención de sustituir el que tengo de 4TB. Pero luego he pensado que podía solamente añadir el disco a la Raspberry. ¿Qué es mejor y menos complicado? ¿Se quedará el sistema más inestable? Espero vuestras sugerencias...
Carlo 4561 Posted June 22, 2021 Posted June 22, 2021 Hi, as long as you can have both drives plugged into the Raspberry Pi server and the files are available you should be just fine using both of them. Emby Server should be able to access all drives plugged into it without a problem. Let us know how you make out.
eltioares 9 Posted June 28, 2021 Posted June 28, 2021 Se te quedara igual no tiene nada que ver. Un saludo.
Danimontes 11 Posted June 30, 2021 Author Posted June 30, 2021 15 minutes ago, Luke said: @eltioares has this helped? I haven't had the chance to do it as I'm far from home and working remotely. As soon as I can, I'll tell you how it's going 1
