brian1709 9 Posted September 13, 2021 Author Posted September 13, 2021 Might be but I am not seeing it. I would expect something like that on Russian or Arabic shows maybe, but not on pure american stuff. So next one Greek (English) straight up American. 2021-09-13 12:14:00.492 T:9608 INFO <general>: INFO: EMBY.core.tvshows.TVShows: UPDATE tvshow [1/548] 354837: Greek 2021-09-13 12:14:00.950 T:7492 WARNING <general>: RunScript called for a non-script addon 'plugin.video.embycon'. This behaviour is deprecated. 2021-09-13 12:14:00.951 T:1416 INFO <general>: initializing python engine. 2021-09-13 12:14:02.736 T:1416 INFO <general>: CPythonInvoker(70, C:\Users\Willem\AppData\Roaming\Kodi\addons\plugin.video.embycon\default.py): script successfully run 2021-09-13 12:14:03.080 T:1416 INFO <general>: Python interpreter stopped 2021-09-13 12:14:13.163 T:4784 INFO <general>: initializing python engine. 2021-09-13 12:14:14.195 T:4784 INFO <general>: SEREN (-1): Seren, Running Path - {'action': 'runMaintenance'} 2021-09-13 12:14:14.237 T:4784 INFO <general>: SEREN (-1): Performing Maintenance 2021-09-13 12:14:14.915 T:4784 INFO <general>: SEREN (-1): Real Debrid: premium 2021-09-13 12:14:15.271 T:4784 INFO <general>: SEREN (-1): All Debrid: premium 2021-09-13 12:14:15.280 T:4784 INFO <general>: SEREN (-1): Init provider packages 2021-09-13 12:14:15.582 T:4784 INFO <general>: CPythonInvoker(71, C:\Users\Willem\AppData\Roaming\Kodi\addons\plugin.video.seren\seren.py): script successfully run 2021-09-13 12:14:16.278 T:4784 INFO <general>: Python interpreter stopped 2021-09-13 12:14:28.161 T:640 INFO <general>: initializing python engine. 2021-09-13 12:14:29.570 T:640 INFO <general>: SEREN (-1): Seren, Running Path - {'action': 'syncTraktActivities'} 2021-09-13 12:14:30.023 T:640 INFO <general>: CPythonInvoker(72, C:\Users\Willem\AppData\Roaming\Kodi\addons\plugin.video.seren\seren.py): script successfully run 2021-09-13 12:14:30.331 T:640 INFO <general>: Python interpreter stopped 2021-09-13 12:14:43.175 T:8040 INFO <general>: initializing python engine. 2021-09-13 12:14:44.279 T:8040 INFO <general>: SEREN (-1): Seren, Running Path - {'action': 'updateLocalTimezone'} 2021-09-13 12:14:44.280 T:8040 INFO <general>: CPythonInvoker(73, C:\Users\Willem\AppData\Roaming\Kodi\addons\plugin.video.seren\seren.py): script successfully run 2021-09-13 12:14:44.943 T:8040 INFO <general>: Python interpreter stopped 2021-09-13 12:15:01.066 T:9608 ERROR <general>: ERROR: EMBY.core.HTTP: [ ServerUnreachable ] 2021-09-13 12:15:01.066 T:9608 ERROR <general>: ERROR: EMBY.core.HTTP: [ ServerUnreachable/retries 1 ] 2021-09-13 12:16:02.091 T:9608 ERROR <general>: ERROR: EMBY.core.HTTP: [ ServerUnreachable ] 2021-09-13 12:16:02.091 T:9608 ERROR <general>: ERROR: EMBY.core.HTTP: [ ServerUnreachable/retries 2 ] 2021-09-13 12:17:03.096 T:9608 ERROR <general>: ERROR: EMBY.core.HTTP: [ ServerUnreachable ] 2021-09-13 12:17:03.096 T:9608 ERROR <general>: ERROR: EMBY.core.HTTP: [ ServerUnreachable/retries 3 ] 2021-09-13 12:18:04.485 T:9608 ERROR <general>: ERROR: EMBY.core.HTTP: [ ServerUnreachable ] 2021-09-13 12:18:04.486 T:9608 INFO <general>: INFO: EMBY.database.db_open.io: [video] 29762 rows updated. 2021-09-13 12:18:04.486 T:5444 INFO <general>: INFO: EMBY.emby.main: ---[ STOP EMBYCLIENT: b8424b13a59f42d6b4df3f0be4e65ad3 ]--- 2021-09-13 12:18:04.486 T:5184 INFO <general>: INFO: Emby.hooks.websocket: ---<[ websocket ] 2021-09-13 12:18:04.486 T:5444 WARNING <general>: WARNING: EMBY.core.HTTP: --<[ session/2048685117056 ] 2021-09-13 12:18:04.519 T:224 INFO <general>: CActiveAESink::OpenSink - initialize sink 2021-09-13 12:18:04.562 T:9608 INFO <general>: INFO: EMBY.database.db_open.io: [b8424b13a59f42d6b4df3f0be4e65ad3] 13186 rows updated. 2021-09-13 12:18:04.570 T:9608 ERROR <general>: Exception in thread 2021-09-13 12:18:04.570 T:9608 ERROR <general>: Thread-9 2021-09-13 12:18:04.570 T:9608 ERROR <general>: : kodi.old.log embyserver.txt
quickmic 1709 Posted September 13, 2021 Posted September 13, 2021 (edited) Try following command: http://172.30.171.239:8096/emby/Shows/354837/Seasons?UserId=6cc7e0cc75924a818f792fa6f1d418c1&EnableImages=True&Fields=Path%2CGenres%2CSortName%2CStudios%2CWriter%2CTaglines%2CLocalTrailerCount%2CVideo3DFormat%2COfficialRating%2CCumulativeRunTimeTicks%2CItemCounts%2CPremiereDate%2CProductionYear%2CMetascore%2CAirTime%2CDateCreated%2CPeople%2COverview%2CCommunityRating%2CStartDate%2CCriticRating%2CCriticRatingSummary%2CEtag%2CShortOverview%2CProductionLocations%2CTags%2CProviderIds%2CParentId%2CRemoteTrailers%2CSpecialEpisodeNumbers%2CStatus%2CEndDate%2CMediaSources%2CVoteCount%2CRecursiveItemCount%2CPrimaryImageAspectRatio%2CDisplayOrder%2CPresentationUniqueKey%2COriginalTitle%2CAlternateMediaSources%2CPartCount%2CSpecialFeatureCount&api_key=XXXXXXXXXXXXXXXXXXXXX you have to replace "XXXXXXXXXXXXXXXXXXXXX" with you api key. You can grab it from: .kodi/userdata/addon_data/plugin.video.emby-next-gen/server_xxxxxxxxxxx.json It's called "AccessToken" ...please post the server response here. Edited September 13, 2021 by quickmic
brian1709 9 Posted September 13, 2021 Author Posted September 13, 2021 it says access token invalid or expired
quickmic 1709 Posted September 13, 2021 Posted September 13, 2021 22 minutes ago, brian1709 said: it says access token invalid or expired The you have inserted the wrong api key from server_xxxxxxxxxxx.json
quickmic 1709 Posted September 13, 2021 Posted September 13, 2021 Should look like that: http://192.168.0.207/emby/Shows/354837/Seasons?UserId=6cc7e0cc75924a818f792fa6f1d418c1&EnableImages=True&Fields=Path%2CGenres%2CSortName%2CStudios%2CWriter%2CTaglines%2CLocalTrailerCount%2CVideo3DFormat%2COfficialRating%2CCumulativeRunTimeTicks%2CItemCounts%2CPremiereDate%2CProductionYear%2CMetascore%2CAirTime%2CDateCreated%2CPeople%2COverview%2CCommunityRating%2CStartDate%2CCriticRating%2CCriticRatingSummary%2CEtag%2CShortOverview%2CProductionLocations%2CTags%2CProviderIds%2CParentId%2CRemoteTrailers%2CSpecialEpisodeNumbers%2CStatus%2CEndDate%2CMediaSources%2CVoteCount%2CRecursiveItemCount%2CPrimaryImageAspectRatio%2CDisplayOrder%2CPresentationUniqueKey%2COriginalTitle%2CAlternateMediaSources%2CPartCount%2CSpecialFeatureCount&api_key=d633a5ea8f4e50f9f8fe0ae878c2c227 btw, don't post the api_key here. This is confidential, the one I used is also just a random key to explain the syntax.
quickmic 1709 Posted September 13, 2021 Posted September 13, 2021 This is how the answer should look like: If you have it, switch to raw mode and export to a file and post it here...
brian1709 9 Posted September 13, 2021 Author Posted September 13, 2021 definitely have the right Key. checked it on a couple of other devices and the server
quickmic 1709 Posted September 13, 2021 Posted September 13, 2021 This is not the key. Open this (text) file. Inside is the key -> It's called "AccessToken"
brian1709 9 Posted September 13, 2021 Author Posted September 13, 2021 have the file have no idea how to get it to raw mode Seasons.json 1
quickmic 1709 Posted September 13, 2021 Posted September 13, 2021 1 hour ago, brian1709 said: have the file have no idea how to get it to raw mode Seasons.json 6.25 kB · 6 downloads I checked the data, seems also ok to me. hmm
brian1709 9 Posted September 13, 2021 Author Posted September 13, 2021 Yea, I looked through the parsed Json and it looked fine to me as well. I have now removed that show from the DB as well and will see how it goes. But so far today I have renamed 2 Folders(Exit and Fighting...) and removed 2 (Gomorra and Greek) and in all instances lockup/freeze goes away. Strange thing though is that Emby Server finds and populates those file fine and correct when I add them new to my media on the server....?
brian1709 9 Posted September 13, 2021 Author Posted September 13, 2021 What is the nfo files used for? Could nfo files in the Folders have an effect on the sync. I could always delete all of that and have the meta data for the whole server refresh.
quickmic 1709 Posted September 13, 2021 Posted September 13, 2021 1 minute ago, brian1709 said: Yea, I looked through the parsed Json and it looked fine to me as well. I have now removed that show from the DB as well and will see how it goes. But so far today I have renamed 2 Folders(Exit and Fighting...) and removed 2 (Gomorra and Greek) and in all instances lockup/freeze goes away. Strange thing though is that Emby Server finds and populates those file fine and correct when I add them new to my media on the server....? Please don't delete all of them, move them in to a backup folder. Probably we can use them for further tests. Something must be "special" with this content.
brian1709 9 Posted September 13, 2021 Author Posted September 13, 2021 also looked at both Greek (Greek (typographically stylized as GRΣΣK) and Gomorrah ( Gomorra - La Serie (Italian) there is special characters in the name which I am not sure is parsed correctly from Emby DB to Kodi DB
quickmic 1709 Posted September 13, 2021 Posted September 13, 2021 1 hour ago, brian1709 said: also looked at both Greek (Greek (typographically stylized as GRΣΣK) and Gomorrah ( Gomorra - La Serie (Italian) there is special characters in the name which I am not sure is parsed correctly from Emby DB to Kodi DB Well. I'll check that too...
quickmic 1709 Posted September 13, 2021 Posted September 13, 2021 16 minutes ago, quickmic said: Well. I'll check that too... 1 hour ago, brian1709 said: also looked at both Greek (Greek (typographically stylized as GRΣΣK) and Gomorrah ( Gomorra - La Serie (Italian) there is special characters in the name which I am not sure is parsed correctly from Emby DB to Kodi DB That's not the problem. Works on Kodi 18 and Kodi 19.
brian1709 9 Posted September 13, 2021 Author Posted September 13, 2021 well it went all the way to "les Honorables" (French) again foreign with sub titles. I am taking that out to see if it will continue.
quickmic 1709 Posted September 13, 2021 Posted September 13, 2021 (edited) 4 minutes ago, brian1709 said: well it went all the way to "les Honorables" (French) again foreign with sub titles. I am taking that out to see if it will continue. Can you send upload the (complete) folder somewhere? Including subtitles, nfo's everything... I assume it will be several Gigabytes, but probably you dropbox, google drive etc? Edited September 13, 2021 by quickmic
brian1709 9 Posted September 13, 2021 Author Posted September 13, 2021 Les Honorables is not that big. Let me see where I can put it. Okay dropbox, it is only 4.8Gb What is your email so I can share it.
quickmic 1709 Posted September 13, 2021 Posted September 13, 2021 2 minutes ago, brian1709 said: Les Honorables is not that big. Let me see where I can put it. Okay dropbox, it is only 4.8Gb What is your email so I can share it. public@rms-systems.net or via PM
brian1709 9 Posted September 13, 2021 Author Posted September 13, 2021 https://www.dropbox.com/sh/bkzxldsvgik2t5p/AABmJGqhfFajSVa5ghVUtC2_a?dl=0 1
brian1709 9 Posted September 13, 2021 Author Posted September 13, 2021 drop box not big enough, so I'll put it on google drive and share. 1
quickmic 1709 Posted September 13, 2021 Posted September 13, 2021 8 minutes ago, brian1709 said: https://www.dropbox.com/sh/bkzxldsvgik2t5p/AABmJGqhfFajSVa5ghVUtC2_a?dl=0 Thanks, download finished, you can remove it.... I'll perform a test...
