brian1709 9 Posted September 10, 2021 Author Posted September 10, 2021 Hi, the screen shot is cut off. I cannot find the manual update link for latest experimental Download link for manual update: https://github.com/MediaBrowser/plugin.video.... 3 hours ago, quickmic said: Please update to latest versions if you go with experimental. 30ex5 is already "damn old", it's a work in progress. I'm sure all those issues are already fixed. Latest versions are always available here (page one), and a new version will be released soon : Â Â
quickmic 1709 Posted September 10, 2021 Posted September 10, 2021 https://kodi.emby.tv/Public testing/plugin.video.emby-next-gen-6.0.6-build 74 (ex8).zip
brian1709 9 Posted September 11, 2021 Author Posted September 11, 2021 Hi, the sync just never finishes. It keeps on failing on the TV shows section about 15-20% in. kodi.log kodi.old.log
quickmic 1709 Posted September 11, 2021 Posted September 11, 2021 (edited) 26 minutes ago, brian1709 said: Hi, the sync just never finishes. It keeps on failing on the TV shows section about 15-20% in. kodi.log 212.41 kB · 0 downloads kodi.old.log 2.14 MB · 0 downloads Thanks, I see the problem. -> ERROR: EMBY.core.HTTP: [ ServerTimeout ]  Is there really no network problem. Frankly, all these issues you have tells me, there is something seriously wrong. Anyway, I can try to use workarounds, but this will not solve your core issue.  A Kodi restart should continue the sync... Edited September 11, 2021 by quickmic
brian1709 9 Posted September 12, 2021 Author Posted September 12, 2021 Seriously no network issue. The sync always stops in the same place with the same file. If I do the sync Movies, music, tv it goes through everything till it gets to Evil in TV shows, and believe me my music collection is huge it takes about 6 hours to sync, so no diconnect If I do TV first it never gets through it just stalls at that area So why would it disconnect at the same place on the same file, sometimes after 5 hours sometimes after 5 minutes, depending on when it gets to that file area.   2021-09-11 15:20:57.965 T:10216   INFO <general>: INFO: EMBY.core.tvshows.TVShows: UPDATE tvshow [2/432] 76257: Evil 2021-09-11 15:21:00.892 T:10216   INFO <general>: INFO: EMBY.core.tvshows.TVShows: UPDATE episode [432/877/8998/12844] 293083: Pilot 2021-09-11 15:21:01.017 T:10216   INFO <general>: INFO: EMBY.core.tvshows.TVShows: UPDATE episode [432/877/8999/12845] 293084: 177 Minutes 2021-09-11 15:21:01.170 T:10216   INFO <general>: INFO: EMBY.core.tvshows.TVShows: UPDATE episode [432/877/9000/12846] 293085: 3 Stars 2021-09-11 15:21:01.329 T:10216   INFO <general>: INFO: EMBY.core.tvshows.TVShows: UPDATE episode [432/877/9001/12847] 293086: Rose390 2021-09-11 15:21:01.451 T:10216   INFO <general>: INFO: EMBY.core.tvshows.TVShows: UPDATE episode [432/877/9002/12848] 293087: October 31 2021-09-11 15:21:01.584 T:10216   INFO <general>: INFO: EMBY.core.tvshows.TVShows: UPDATE episode [432/877/9003/12849] 293088: Let x = 9 2021-09-11 15:21:01.710 T:10216   INFO <general>: INFO: EMBY.core.tvshows.TVShows: UPDATE episode [432/877/9004/12850] 293089: Vatican III 2021-09-11 15:21:01.870 T:10216   INFO <general>: INFO: EMBY.core.tvshows.TVShows: UPDATE episode [432/877/9005/12851] 293090: 2 Fathers 2021-09-11 15:21:02.019 T:10216   INFO <general>: INFO: EMBY.core.tvshows.TVShows: UPDATE episode [432/877/9006/12852] 293091: Exorcism Part 2 2021-09-11 15:21:02.161 T:10216   INFO <general>: INFO: EMBY.core.tvshows.TVShows: UPDATE episode [432/877/9007/12853] 293092: 7 Swans A Singin' 2021-09-11 15:21:02.300 T:10216   INFO <general>: INFO: EMBY.core.tvshows.TVShows: UPDATE episode [432/877/9008/12854] 293093: Room 320 2021-09-11 15:21:02.389 T:10216   INFO <general>: INFO: EMBY.core.tvshows.TVShows: UPDATE episode [432/877/9009/12855] 293094: Justice x 2 2021-09-11 15:21:02.486 T:10216   INFO <general>: INFO: EMBY.core.tvshows.TVShows: UPDATE episode [432/877/9010/12856] 293095: Book 27 2021-09-11 15:21:03.854 T:10216   INFO <general>: INFO: EMBY.core.tvshows.TVShows: UPDATE episode [432/878/9011/12857] 508848: N is for Night Terrors 2021-09-11 15:21:03.948 T:10216   INFO <general>: INFO: EMBY.core.tvshows.TVShows: UPDATE episode [432/878/9012/12858] 513861: A is for Avenging Angel 2021-09-11 15:21:04.016 T:10216   INFO <general>: INFO: EMBY.core.tvshows.TVShows: UPDATE episode [432/878/9013/12859] 513862: F is for Fire 2021-09-11 15:21:04.089 T:10216   INFO <general>: INFO: EMBY.core.tvshows.TVShows: UPDATE episode [432/878/9014/12860] 513863: E is for Elevator 2021-09-11 15:21:04.165 T:10216   INFO <general>: INFO: EMBY.core.tvshows.TVShows: UPDATE episode [432/878/9015/12861] 514959: Z is for Zombies 2021-09-11 15:21:04.236 T:10216   INFO <general>: INFO: EMBY.core.tvshows.TVShows: UPDATE episode [432/878/9016/12862] 515807: C is for Cop 2021-09-11 15:21:04.308 T:10216   INFO <general>: INFO: EMBY.core.tvshows.TVShows: UPDATE episode [432/878/9017/12863] 526620: S is for Silence 2021-09-11 15:21:04.374 T:10216   INFO <general>: INFO: EMBY.core.tvshows.TVShows: UPDATE episode [432/878/9018/12864] 529548: T is for Temporoparietal Lobes 2021-09-11 15:21:04.834 T:10216   INFO <general>: INFO: EMBY.core.tvshows.TVShows: UPDATE tvshow [2/433] 318253: Exit (2019) 2021-09-11 15:21:18.700 T:8844   INFO <general>: initializing python engine. 2021-09-11 15:21:19.933 T:9120  WARNING <general>: CGUIWindowManager - CGUIWindowManager::HandleAction - ignoring action 103, because topmost modal dialog closing animation is running 2021-09-11 15:21:20.167 T:8844   INFO <general>: CPythonInvoker(44, C:\Users\Willem\AppData\Roaming\Kodi\addons\script.logviewer\default.py): script successfully run 2021-09-11 15:21:20.661 T:8844   INFO <general>: Python interpreter stopped 2021-09-11 15:21:26.825 T:7248   INFO <general>: initializing python engine. 2021-09-11 15:21:33.182 T:7248   INFO <general>: CPythonInvoker(45, C:\Users\Willem\AppData\Roaming\Kodi\addons\script.logviewer\default.py): script successfully run 2021-09-11 15:21:33.750 T:7248   INFO <general>: Python interpreter stopped 2021-09-11 15:22:04.877 T:10216  ERROR <general>: ERROR: EMBY.core.HTTP: [ ServerTimeout ] 2021-09-11 15:22:04.878 T:10216   INFO <general>: INFO: EMBY.database.db_open.io: [video] 19646 rows updated. 2021-09-11 15:22:04.981 T:10216   INFO <general>: INFO: EMBY.database.db_open.io: [b8424b13a59f42d6b4df3f0be4e65ad3] 10725 rows updated. 2021-09-11 15:22:04.991 T:10216  ERROR <general>: Exception in thread 2021-09-11 15:22:04.992 T:10216  ERROR <general>: Thread-9 2021-09-11 15:22:04.992 T:10216  ERROR <general>: :                           2021-09-11 15:22:04.992 T:10216  ERROR <general>: Traceback (most recent call last):                           2021-09-11 15:22:04.992 T:10216  ERROR <general>:  File "C:\Program Files\Kodi\system\python\Lib\threading.py", line 932, in _bootstrap_inner                           2021-09-11 15:22:04.992 T:10216  ERROR <general>:    2021-09-11 15:22:04.993 T:10216  ERROR <general>: self.run() 2021-09-11 15:22:04.993 T:10216  ERROR <general>:                           2021-09-11 15:22:04.993 T:10216  ERROR <general>:  File "C:\Program Files\Kodi\system\python\Lib\threading.py", line 870, in run                           2021-09-11 15:22:04.993 T:10216  ERROR <general>:    2021-09-11 15:22:04.993 T:10216  ERROR <general>: self._target(*self._args, **self._kwargs) 2021-09-11 15:22:04.993 T:10216  ERROR <general>:                           2021-09-11 15:22:04.993 T:10216  ERROR <general>:  File "C:\Users\Willem\AppData\Roaming\Kodi\addons\plugin.video.emby-next-gen\database\library.py", line 565, in RunJobs                           2021-09-11 15:22:04.994 T:10216  ERROR <general>:    2021-09-11 15:22:04.994 T:10216  ERROR <general>: self.worker_library() 2021-09-11 15:22:04.994 T:10216  ERROR <general>:                           2021-09-11 15:22:04.994 T:10216  ERROR <general>:  File "C:\Users\Willem\AppData\Roaming\Kodi\addons\plugin.video.emby-next-gen\database\library.py", line 447, in worker_library                           2021-09-11 15:22:04.994 T:10216  ERROR <general>:    2021-09-11 15:22:04.995 T:10216  ERROR <general>: DBObject(Item, LibraryData, ProgressValue, False) 2021-09-11 15:22:04.995 T:10216  ERROR <general>:                           2021-09-11 15:22:04.995 T:10216  ERROR <general>:  File "C:\Users\Willem\AppData\Roaming\Kodi\addons\plugin.video.emby-next-gen\core\tvshows.py", line 121, in tvshow                           2021-09-11 15:22:04.995 T:10216  ERROR <general>:    2021-09-11 15:22:04.995 T:10216  ERROR <general>: Seasons = self.EmbyServer.API.get_seasons(obj['Id'])['Items'] 2021-09-11 15:22:04.995 T:10216  ERROR <general>:                           2021-09-11 15:22:04.995 T:10216  ERROR <general>: KeyError 2021-09-11 15:22:04.995 T:10216  ERROR <general>: : 2021-09-11 15:22:04.995 T:10216  ERROR <general>: 'Items' 2021-09-11 15:22:04.995 T:10216  ERROR <general>:                           2021-09-11 15:22:22.424 T:9588   INFO <general>: CActiveAESink::OpenSink - initialize sink 2021-09-11 15:22:23.503 T:9588  WARNING <general>: CWin32DirectSound::GetSpace - buffer underrun - W:42840, P:28544, O:42304. 2021-09-11 15:22:44.315 T:7672   INFO <general>: initializing python engine. 2021-09-11 15:22:50.525 T:7672   INFO <general>: CPythonInvoker(46, C:\Users\Willem\AppData\Roaming\Kodi\addons\script.logviewer\default.py): script successfully run 2021-09-11 15:22:51.062 T:7672   INFO <general>: Python interpreter stopped 2021-09-11 15:24:41.870 T:6400   INFO <general>: initializing python engine. 2021-09-11 15:24:52.246 T:6400   INFO <general>: CPythonInvoker(47, C:\Users\Willem\AppData\Roaming\Kodi\addons\script.logviewer\default.py): script successfully run 2021-09-11 15:24:52.793 T:6400   INFO <general>: Python interpreter stopped 2021-09-11 15:25:17.622 T:8464   INFO <general>: initializing python engine. 2021-09-11 15:25:23.109 T:8464   INFO <general>: CPythonInvoker(48, C:\Users\Willem\AppData\Roaming\Kodi\addons\script.logviewer\default.py): script successfully run 2021-09-11 15:25:23.558 T:8464   INFO <general>: Python interpreter stopped 2021-09-11 15:25:33.962 T:9120   INFO <general>: Stopping player 2021-09-11 15:25:33.962 T:9120   INFO <general>: Storing total System Uptime 2021-09-11 15:25:33.962 T:9120   INFO <general>: Saving settings 2021-09-11 15:25:33.966 T:9120   INFO <general>: Saving skin settings 2021-09-11 15:25:33.976 T:9120   INFO <general>: Stopping all 2021-09-11 15:25:34.566 T:6128  WARNING <general>: WARNING: EMBY.entrypoint.Service: ---<[ EXITING ] 2021-09-11 15:25:34.566 T:8984   INFO <general>: INFO: EMBY.hooks.webservice.WebService: ---<[ webservice/57578 ] 2021-09-11 15:25:34.567 T:6128   INFO <general>: INFO: EMBY.emby.main: ---[ STOP EMBYCLIENT: b8424b13a59f42d6b4df3f0be4e65ad3 ]--- 2021-09-11 15:25:34.567 T:2156   INFO <general>: INFO: Emby.hooks.websocket: ---<[ websocket ] 2021-09-11 15:25:34.567 T:6128  WARNING <general>: WARNING: EMBY.core.HTTP: --<[ session/2678261889008 ] 2021-09-11 15:25:34.568 T:6128  WARNING <general>: [ emby-for-kodi-next-gen shutdown ] 2021-09-11 15:25:34.568 T:6128   INFO <general>: CPythonInvoker(4, C:\Users\Willem\AppData\Roaming\Kodi\addons\plugin.video.emby-next-gen\service.py): script successfully run 2021-09-11 15:25:34.568 T:6128   INFO <general>: CPythonInvoker(4, C:\Users\Willem\AppData\Roaming\Kodi\addons\plugin.video.emby-next-gen\service.py): waiting on thread 8032 2021-09-11 15:25:43.854 T:6128   INFO <general>: CPythonInvoker(4, C:\Users\Willem\AppData\Roaming\Kodi\addons\plugin.video.emby-next-gen\service.py): waiting on thread 9500 Â
brian1709 9 Posted September 12, 2021 Author Posted September 12, 2021 well figured it out. There was an episode in there that had a space in the name   Exit.S01 E01 which made it fail all the time. Took the space out and it completed the sync. A bit surprised that something like that could make it fail. and only on this one machine, the rest ran straight over that issue. 1
brian1709 9 Posted September 12, 2021 Author Posted September 12, 2021 Spoke to quickly, it just went a little further and then found a new folder/TV Show it didn't like and now it hangs on that. (Fighting Season) Ran it three times in different order, movies first(complete), TV second (fails) Music first(complete) Movies(complete) TV (fails) TV first (fails) The folder contain 6 episodes, correctly named and numbered and nfo file for each kodi.log kodi.old.log
quickmic 1709 Posted September 12, 2021 Posted September 12, 2021 (edited) 16 minutes ago, brian1709 said: Spoke to quickly, it just went a little further and then found a new folder/TV Show it didn't like and now it hangs on that. (Fighting Season) Ran it three times in different order, movies first(complete), TV second (fails) Music first(complete) Movies(complete) TV (fails) TV first (fails) The folder contain 6 episodes, correctly named and numbered and nfo file for each kodi.log 2.2 MB · 0 downloads kodi.old.log 417.4 kB · 0 downloads It's always the same issue: ERROR: EMBY.core.HTTP: [ ServerTimeout ] I'll add a workaround in next version, but a ServerTimeout should never appear. The timeout settings is 60 seconds and this exactly what you log shows. The server didn't response for 60 seconds what is totally odd.  Please send me the emby server log. Next-gen waited here for server answer: 2021-09-12 18:53:48.287 T:1916 INFO <general>: INFO: EMBY.core.tvshows.TVShows: ADD tvshow [2/459] 330672: Fighting Season 2021-09-12 18:54:48.320 T:1916 ERROR <general>: ERROR: EMBY.core.HTTP: [ ServerTimeout ]  I wanna check the emby server log for this timespan, probably there is something odd in the log.   Edited September 12, 2021 by quickmic
brian1709 9 Posted September 13, 2021 Author Posted September 13, 2021 attached embyserver-63767087992.txt 1
brian1709 9 Posted September 13, 2021 Author Posted September 13, 2021 Same thing happened at 2021-09-12 17:39:34.929 T:4940   INFO <general>: INFO: EMBY.core.tvshows.TVShows: ADD tvshow [2/458] 330672: Fighting Season 2021-09-12 17:40:35.005 T:4940   ERROR <general>: ERROR: EMBY.core.HTTP: [ ServerTimeout ] 2021-09-12 17:40:35.005 T:4940   INFO <general>: INFO: EMBY.database.db_open.io: [video] 33134 rows updated. 2021-09-12 17:40:35.187 T:3248   INFO <general>: VideoInfoScanner: Finished scan. Scanning for video info took 01:21 2021-09-12 17:40:35.194 T:4940   INFO <general>: INFO: EMBY.database.db_open.io: [b8424b13a59f42d6b4df3f0be4e65ad3] 14239 rows updated.  which is also in the log, and like I said it used to happen continuously on another TV Show  EXIT till I changed the naming of the files to delete a space. So it seems to have an issue with a folder or file and then times out (60 sec)
quickmic 1709 Posted September 13, 2021 Posted September 13, 2021 (edited) Please drop the naming which stalled the sync. Also tell me which tag field in metadata manager on Emby server caused the issue. Probably you can post a screenshot? And the nfo file if you use them. Edited September 13, 2021 by quickmic
brian1709 9 Posted September 13, 2021 Author Posted September 13, 2021 1 hour ago, quickmic said: Â Also tell me which tag field in metadata manager on Emby server caused the issue. Probably you can post a screenshot? Â where would I find this?
brian1709 9 Posted September 13, 2021 Author Posted September 13, 2021 Thought so, but there is no tags applied. I did change the name of the folder from Fighting.Season to Fighting Season as well as the six media files inside. Here is the new nfo tvshow.nfo
quickmic 1709 Posted September 13, 2021 Posted September 13, 2021 11 minutes ago, brian1709 said: I did change the name of the folder from Fighting.Season to Fighting Season as well as the six media files inside. "Fighting.Season" was the folder name on you harddrive which caused the problem, right? After rename to "Fighting Season" it works? Please confirm, and I'll design a test case based on that.
brian1709 9 Posted September 13, 2021 Author Posted September 13, 2021 testing it now. What I did notice is that both folders that caused lockups were considered foreign by way of the tag setting which by default is English USA While EXIT was Norwegian with subs, Fighting Season is Australian English ?
brian1709 9 Posted September 13, 2021 Author Posted September 13, 2021 Ok, it went right past Fighting Season no problem. Then just got stuck a little bit further on Generation 56K Again the Folder is named Generation.56K and is Foreign (Italian) The log shows the same error    ERROR <general>: ERROR: EMBY.core.HTTP: [ ServerTimeout ] but that cannot be right as I can play content from the server while it is supposedly disconnected or timing out. I tried it a couple of times. Restart the sync, as soon as it stalls tries to play something and it works fine, so it is definitely connected to the server while the sync says it is not. Also tried by starting to play a movie and while it is playing starting the sync, it just gets stuck at Generation.56K and then times out. Something on the naming convention or the fact that it is "Foreign" is causing it to crap out. Of course the DB comes from EMBY and is perfect in EMBYCON and Emby Theatre
brian1709 9 Posted September 13, 2021 Author Posted September 13, 2021 Sorry, here are the log kodi.log kodi.old.log
brian1709 9 Posted September 13, 2021 Author Posted September 13, 2021 Definitely something with folder/file naming. Changed Generation.56k to Generation 56k on both file s and folder and it just went through right away
quickmic 1709 Posted September 13, 2021 Posted September 13, 2021 1 minute ago, brian1709 said: Definitely something with folder/file naming. Changed Generation.56k to Generation 56k on both file s and folder and it just went through right away I'm performing a test right now... I hope I can reproduce the issue...
brian1709 9 Posted September 13, 2021 Author Posted September 13, 2021 Folder not file naming. Got another one, Folder Gomorrah (Italian) with subs The Italian show was just Gomorra, Changed folder to Gomorra and left file names Gomorrah and it went through. 1
quickmic 1709 Posted September 13, 2021 Posted September 13, 2021 (edited) 9 minutes ago, brian1709 said: Folder not file naming. Got another one, Folder Gomorrah (Italian) with subs The Italian show was just Gomorra, Changed folder to Gomorra and left file names Gomorrah and it went through. I'm not able to reproduce the issue. If you find another one, don't fix it. Please let send me th ekodi long and emby server log. I'll build a command based on that info and post it here with instuctions how to use it. Sorry for the inconviniance, but this is a tough issue.... Edited September 13, 2021 by quickmic
brian1709 9 Posted September 13, 2021 Author Posted September 13, 2021 OK, will do. Could not fix Gomorra/h at all. Removed the folder and it continued freeze stopped and sync continued on
quickmic 1709 Posted September 13, 2021 Posted September 13, 2021 (edited) 6 minutes ago, brian1709 said: OK, will do. Could not fix Gomorra/h at all. Removed the folder and it continued freeze stopped and sync continued on I assume, but this pure speculation, there are special charecter is the foldername or subfolders or metatag which stalls Kodi or the Emby server. Special charecters -> I mean invisible ones (hard to describe), machine command charecters, something like that. Anyway, I try to build the command Kodi sent manually. This request could be dropped into the browser and review the response. Also you can enable debug log mode on Kodi and Emby server.  Edited September 13, 2021 by quickmic
