Carlo 4561 Posted June 24, 2021 Posted June 24, 2021 @Spaceboy any chance we could ask you to zip up the album/track and a music video (or cut version of one) we could use to test with?
Happy2Play 9802 Posted June 24, 2021 Posted June 24, 2021 11 minutes ago, Spaceboy said: Fun times. I can reproduce. I have the same MV, correctly tagged but for some reason emby reads that as weirder, i have another track also called Faded but by a different artist. Also tagged correctly also read wrongly by Emby as the same incorrect artist i don't have any MBz information in the MV tags, just what you can see in the images above and MBz is not a metadata provider for my MV library. So why has emby returned Lyves as the artist?? Do you have any providers enabled on your Music Videos library as I did get my Faded MV linked to Stan Walker on import do to enabled Providers and garbage metadata. But yes we need more information for this topic to test variables.
Guest Posted June 24, 2021 Posted June 24, 2021 This is now absurd and a little sad. Just use youtube-dl to rip the video from YouTube. There's no metadata, it's a blank slate. Wipe all the metadata from the music files, then just add the artist/album artist to the tags, and add the files to emby. This really is sad.
Happy2Play 9802 Posted June 24, 2021 Posted June 24, 2021 4 minutes ago, generiq said: This is now absurd and a little sad. Just use youtube-dl to rip the video from YouTube. There's no metadata, it's a blank slate. Wipe all the metadata from the music files, then just add the artist/album artist to the tags, and add the files to emby. This really is sad. But it just works (for me) unless I have no music from said artist then I see Emby got the wrong artist in the ZHU example it was linked to ZHU ZHU artist instead. Can only assume a mbz query issue as that artist is first on mbz.
Guest Posted June 24, 2021 Posted June 24, 2021 Yes, without the musicbrainz ID, it works. Which is what I have resorted to doing. If you add the MBZ ID to the extended tag of the music and not the video, it breaks it.
Happy2Play 9802 Posted June 24, 2021 Posted June 24, 2021 29 minutes ago, generiq said: Yes, without the musicbrainz ID, it works. Which is what I have resorted to doing. If you add the MBZ ID to the extended tag of the music and not the video, it breaks it. But I can not produce that behavior. And the ZHU example I removed the MV, added a fully tagged Album, then readded MV and it then linked to the correct ZHU artist pre the Albums metadata. As it created a proper database entry for the Artist will all appropriate information.
Guest Posted June 24, 2021 Posted June 24, 2021 This is pointless, and very sad. I've added the appropriate heading to the first post.
Happy2Play 9802 Posted June 24, 2021 Posted June 24, 2021 No need to lock, we just need to identify the variable to recreate the issue as I have tested dozens of times to reproduce and will continue. So all variable will need to be known to reproduce as me adding or removing MBZid from Music have not made any difference in my testing.
Happy2Play 9802 Posted June 24, 2021 Posted June 24, 2021 (edited) 19 hours ago, Luke said: Right we support the same tags for videos as we do for audio files. Can you look at this as I added a MV with Artist and MBZArtistid and Emby got the wrong Artists as mentioned above. It got ZHU artist with MBZArtistid for ZHU ZHU not the one tagged in MV. Note no music existed for the Artist at the time. Edited June 24, 2021 by Happy2Play
