Bambu Utila 9 Posted June 22, 2021 Posted June 22, 2021 (edited) Hi, I'm running Emby server v 4.6.3.0 in docker on OpenMediaVault Without changing anything to my muisc or Emby install, other than upgrading the docker container when there is a new version of Emby my playlists stopped working If I check them out there are only some or no songs at all in the playlists anymore. When i check the playlist.xml file for the playlist it still shows all the songs for the playlists that still have some songs in them. For the playlists that are completely empty now it has no songs in the playlist.xml file. When i look up the songs in the music library they are all still there and work as expected Any help would be appreciated Edited June 22, 2021 by Bambu Utila
Solution Luke 42203 Posted June 22, 2021 Solution Posted June 22, 2021 Hi, try refreshing the metadata on one of these playlists and see if that helps. 1
Bambu Utila 9 Posted June 22, 2021 Author Posted June 22, 2021 Thank you so much! That did the trick 1
