qiaqiaxian 0 Posted June 21, 2021 Posted June 21, 2021 I can see additional parts of moive through web but can't see addtional parts on TV Is there any way to show additional parts on TV?
Carlo 4561 Posted June 21, 2021 Posted June 21, 2021 Hi, What are these additional parts you're referring to? Can you provide a picture if possible?
ebr 16338 Posted June 21, 2021 Posted June 21, 2021 Hi. The Android TV app does not show them to you but will play them in succession if you play the item. You should consider combining the files for much better functionality all around (resume, run time, chapters, etc.).
qiaqiaxian 0 Posted June 21, 2021 Author Posted June 21, 2021 59 minutes ago, pwhodges said: What TV client? Paul Android TV SONY 9500h
qiaqiaxian 0 Posted June 21, 2021 Author Posted June 21, 2021 8 minutes ago, ebr said: Hi. The Android TV app does not show them to you but will play them in succession if you play the item. You should consider combining the files for much better functionality all around (resume, run time, chapters, etc.). It's a very time-consuming job. I have a lot of videos like part#. Will you consider adding relevant feature in the future?
qiaqiaxian 0 Posted June 21, 2021 Author Posted June 21, 2021 46 minutes ago, cayars said: Hi, What are these additional parts you're referring to? Can you provide a picture if possible? multiple parts video
ebr 16338 Posted June 22, 2021 Posted June 22, 2021 19 hours ago, qiaqiaxian said: It's a very time-consuming job. I have a lot of videos like part#. Will you consider adding relevant feature in the future? Yes, we will eventually but you still will have a much less rich experience. Things like resume and chapters simply will not work as well. Combining the files is really the best long-term option. Thanks.
Jerren 18 Posted June 25, 2021 Posted June 25, 2021 I'm glad others seem to still run into this aswell, other posts i found on a quick google search seemed to be from 2015 so i was a bit confused if this issue dissapeared for others. Are there any tips on what program or tools is best to combine video files like this without losing quality (or atleast only a little) and keeping the file size down?
ebr 16338 Posted June 25, 2021 Posted June 25, 2021 Hi. I've heard people use mkvmerge and also even just ffmpeg with a simple command line. There should be zero quality loss as the files are simply concatenated.
roaku 842 Posted June 25, 2021 Posted June 25, 2021 MKVToolNix is very good. It's from the same people as mkvmerge and provides a nice GUI layer for their command line tools that simplifies the process.
Jerren 18 Posted June 25, 2021 Posted June 25, 2021 Thanks for the tips, just used MKVToolNix to try and merge one and it all looks and sounds good, it even reduced the filesize with 300mb oddly enough. Thanks again! 2
