trexallen 0 Posted June 20, 2021 Posted June 20, 2021 Hello, I have Emby running on a remote server and I am able to access my library through both iOS and through a web browser, however, when trying to setup the Emby app through my appleTV I run into the following problems. After installing the Emby app I get the option to sign in by using Emby Connect and I have a pin. I go onto a browser and put in my login info along with the pin which all works as it should. The Emby app on my appletv then goes to a screen where I assume that my server is meant to appear but it does not. So I manually try to add my server using my URL but I just get an error saying connection failure. Please could anyone assist me. Thanks.
Luke 42241 Posted July 8, 2021 Posted July 8, 2021 hi @trexallen are you still having an issue with this? When you manually enter the address, is it an http or https address?
kryptovik1 1 Posted October 21, 2022 Posted October 21, 2022 Hi, I am having the exact same issue, mine is with https. Thanx
kryptovik1 1 Posted October 21, 2022 Posted October 21, 2022 2 minutes ago, Luke said: Hi, does this look like your issue? Issue resolved ,thanx.. had to add 433 port within my server url 1
