ddxp1090 0 Posted June 20, 2021 Posted June 20, 2021 Hi I am wanting to convert the .ts file to .mkv after recording using the Post Processing feature but not fond of writing shell scripts. I am using the standard x64 Emby package on a DS920+. Can somebody tell me the ffmpeg path to execute?
FrostByte 5454 Posted June 20, 2021 Posted June 20, 2021 (edited) Mine is located here /volume1/@appstore/EmbyServer/bin/ffmpeg Also, I think this script converts ts to mkv, but you might need to modify paths, etc Post Processing Script - Working Example - Powershell - Tools and Utilities - Emby Community Edited June 20, 2021 by FrostByte 1
MAX92 93 Posted July 6, 2021 Posted July 6, 2021 @ddxp1090: Do you succeed in post processing .ts file ?
