emveepee 133 Posted June 21, 2021 Posted June 21, 2021 I'd need to see the NextPVR server side logs. It is not clear what error this is but I assume it must be a 404. MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: NotFound If you are running a VPN, NextPVR could think you are remote. Martin
Luke 42239 Posted June 21, 2021 Posted June 21, 2021 28 minutes ago, Globalnetwork said: do you mean this embyserver.txt 52.28 kB · 2 downloads embyserver-63759703513.txt 142.12 kB · 3 downloads embyserver-63759703536.txt 853 B · 1 download embyserver-63759772623.txt 55.52 kB · 1 download embyserver-63759793985.txt 155.99 kB · 1 download embyserver-63759802591.txt 389.07 kB · 1 download embyserver-63759890812.txt 107.4 kB · 0 downloads embyserver-63759907155.txt 516.93 kB · 0 downloads embyserver-63759916800.txt 300.71 kB · 0 downloads embyserver-63759917033.txt 31.98 kB · 0 downloads embyserver-63759917586.txt 246.12 kB · 1 download embyserver-63759917842.txt 353.22 kB · 0 downloads embyserver-63759918089.txt 164.12 kB · 0 downloads embyserver-63759918430.txt 143.56 kB · 0 downloads embyserver-63759919041.txt 128.17 kB · 0 downloads embyserver-63759919104.txt 68.64 kB · 0 downloads hardware_detection-63759698871.txt 138.64 kB · 0 downloads hardware_detection-63759703579.txt 138.64 kB · 0 downloads hardware_detection-63759772675.txt 138.64 kB · 0 downloads hardware_detection-63759794039.txt 138.64 kB · 0 downloads hardware_detection-63759802617.txt 138.64 kB · 0 downloads hardware_detection-63759890872.txt 138.64 kB · 0 downloads hardware_detection-63759907215.txt 138.64 kB · 0 downloads hardware_detection-63759917058.txt 138.64 kB · 0 downloads hardware_detection-63759917605.txt 138.64 kB · 0 downloads hardware_detection-63759917861.txt 138.64 kB · 0 downloads hardware_detection-63759918108.txt 138.64 kB · 0 downloads hardware_detection-63759918450.txt 138.64 kB · 0 downloads hardware_detection-63759919060.txt 138.64 kB · 0 downloads hardware_detection-63759919125.txt 138.64 kB · 0 downloads Hi, which server log file is from the timeframe in which you ran the refresh guide scheduled task?
Globalnetwork 0 Posted June 21, 2021 Author Posted June 21, 2021 3 minutes ago, emveepee said: I'd need to see the NextPVR server side logs. It is not clear what error this is but I assume it must be a 404. MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: NotFound If you are running a VPN, NextPVR could think you are remote. Martin no running a VPN
Globalnetwork 0 Posted June 21, 2021 Author Posted June 21, 2021 5 minutes ago, emveepee said: I'd need to see the NextPVR server side logs. It is not clear what error this is but I assume it must be a 404. MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: NotFound If you are running a VPN, NextPVR could think you are remote. Martin NextPVR server side logs. device-Digital TV-1.log devices.log NPVR.log nrecord.log
Globalnetwork 0 Posted June 21, 2021 Author Posted June 21, 2021 9 minutes ago, Luke said: Hi, which server log file is from the timeframe in which you ran the refresh guide scheduled task? I don't know exactly
emveepee 133 Posted June 21, 2021 Posted June 21, 2021 (edited) Assuming you want to use the default PIN "0000", you have an extra zero in Emby so 2021-06-22 00:21:42.898 Error App: [NextPVR] PIN not accepted. Martin Edited June 21, 2021 by emveepee
Globalnetwork 0 Posted June 22, 2021 Author Posted June 22, 2021 6 hours ago, emveepee said: Assuming you want to use the default PIN "0000", you have an extra zero in Emby so 2021-06-22 00:21:42.898 Error App: [NextPVR] PIN not accepted. Martin I have done PIN "0000", in NextPVR and also in Emby The channels did not appear
emveepee 133 Posted June 22, 2021 Posted June 22, 2021 You had many tests with many different error trying things. Could you duplicate after you are sure you have the same PIN in both configurations and send just the current Emby log. Martin
Globalnetwork 0 Posted June 22, 2021 Author Posted June 22, 2021 6 hours ago, emveepee said: You had many tests with many different error trying things. Could you duplicate after you are sure you have the same PIN in both configurations and send just the current Emby log. Martin embyserver.txt
emveepee 133 Posted June 22, 2021 Posted June 22, 2021 Seems to be loading channels right now Go to Scheduled Task to see the status of the guide update. As I said it can be slow. As of this run there is no EPG data carried over, but your screenshot didn't have many either. Martin
Globalnetwork 0 Posted June 22, 2021 Author Posted June 22, 2021 3 hours ago, emveepee said: Seems to be loading channels right now Go to Scheduled Task to see the status of the guide update. As I said it can be slow. As of this run there is no EPG data carried over, but your screenshot didn't have many either. Martin Same problem, channels are not showing up
Carlo 4561 Posted June 22, 2021 Posted June 22, 2021 What does the schedule show for this? How long did it run for? Can you take a picture?
arrbee99 1836 Posted June 22, 2021 Posted June 22, 2021 I guess nothing to do with User Access or something ? Live TV is Enabled for the Home Screen. You personally have Feature Access to Live TV. I guess its not a problem, or would have been mentioned already.
emveepee 133 Posted June 22, 2021 Posted June 22, 2021 Please no shouting. Do you mean no channels or no guide data? There should a channel list when you click Live TV -> Channels since Emby is requesting 565 separate EPG listings so it does now channels exist. Martin
Globalnetwork 0 Posted June 23, 2021 Author Posted June 23, 2021 Thank you very much everyone Finally, the channels have appeared
