Kyononono 0 Posted June 19, 2021 Posted June 19, 2021 (edited) Hello, There's a lot of information about this topic but I still can't find something that would help me. All of this is new to me so please bare with me here. I have Emby installed on my Gaming PC (Ryzen 2700X, RTX 2080, 48 GB RAM) and have couple of anime that I want to play on my Android TV (Philips 50PUS7303). Sadly every single episode is so unwatchable on a TV. I understand that this format is heavy on CPU and Android TVs cannot handle that but from what I understand point of Emby Server is to use it's resource to transcode (?) and make it watchable. I tried toying with the settings but with no success. I'd be very grateful for help. I attached the logs, if you require anything else just let me know. Thank you. hardware_detection-63759691716.txtembyserver-63759691764.txt mediainfo.txt Edited June 19, 2021 by Kyononono
Abobader 3485 Posted June 19, 2021 Posted June 19, 2021 Hello Kyononono, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
rodainas 191 Posted June 19, 2021 Posted June 19, 2021 Did you enable transcoding for the user? settings, server, users, you user, media playback, allow video playback that requires transcoding
ebr 16309 Posted June 19, 2021 Posted June 19, 2021 2 hours ago, Kyononono said: Sadly every single episode is so unwatchable on a TV. Hi. Exactly what happens? What is "unwatchable"?
Kyononono 0 Posted June 19, 2021 Author Posted June 19, 2021 Sorry, I should've been more specific. I can hear the audio and see subtitles just fine but the screen is either black or freezes on 1 frame and refreshes every 1-2 minutes.
ebr 16309 Posted June 19, 2021 Posted June 19, 2021 The log you posted does not appear to be from playback. Are you sure it is the right one? Were any ffmpeg logs created?
Kyononono 0 Posted June 19, 2021 Author Posted June 19, 2021 (edited) Cannot find any ffmpeg logs on the Server. Not sure if it helps but I did send logs from my Android TV (using the in app option) about 5 minutes ago. My AppData\Roaming\Emby-Server\programdata\logs folder: Thank you. Edited June 19, 2021 by Kyononono
GrimReaper 4861 Posted June 19, 2021 Posted June 19, 2021 Have you tried selecting "Playback correction" in the OSD?
Kyononono 0 Posted June 19, 2021 Author Posted June 19, 2021 Hi, I just tried it but it didn't have any effect on the video. However it did create a ffmpeg log. ffmpeg-remux-fe3a8853-a8db-4490-b583-daa4031d5634_1.txt
GrimReaper 4861 Posted June 19, 2021 Posted June 19, 2021 Try lowering quality below that media bitrate, 3-4 Mbps or lower, and see does it make a difference?
Kyononono 0 Posted June 19, 2021 Author Posted June 19, 2021 Tried lowering Quality to 1-4 Mbps but everytime I got a popup "Too many errors. Giving up". It created a lot of ffmpeg logs, I zipped all of them. logs1.zip
GrimReaper 4861 Posted June 19, 2021 Posted June 19, 2021 Do you have Emby Premiere subscription (which would enable HW accelleration)?
Kyononono 0 Posted June 19, 2021 Author Posted June 19, 2021 I installed emby few days ago and I was under the impression that it offered a free trial. A message that a trial will expire keeps popping on my Android TV when I start playback. Is HW acceleration still blocked even if I'm on trial?
GrimReaper 4861 Posted June 19, 2021 Posted June 19, 2021 3 minutes ago, Kyononono said: I installed emby few days ago and I was under the impression that it offered a free trial. A message that a trial will expire keeps popping on my Android TV when I start playback. Is HW acceleration still blocked even if I'm on trial? I don't think server has a trial, only certain client apps (like Android TV app) do, which is unrelated to server-side Premiere subscription benefits, but I beleive @ebr will give you more insight on that. https://support.emby.media/support/solutions/articles/44001173099-emby-premiere-feature-matrix
Kyononono 0 Posted June 19, 2021 Author Posted June 19, 2021 (edited) I purchased Premiere subscription just now and tested things again but sadly no change. I don't get an error while using Playback correction now but sadly it does not help. Edited June 19, 2021 by Kyononono
GrimReaper 4861 Posted June 19, 2021 Posted June 19, 2021 Did you insert your Premiere key in Dashboard>Emby Premiere tab? Is it active already?
Kyononono 0 Posted June 19, 2021 Author Posted June 19, 2021 Yes, the status says: "You have a Monthly Emby Premiere plan and your device usage is well within your limit."
GrimReaper 4861 Posted June 19, 2021 Posted June 19, 2021 Now try playback with lower bitrate to see is your 2080 taking the load.
Kyononono 0 Posted June 19, 2021 Author Posted June 19, 2021 (edited) I'm getting "Too many errors. Giving up" message. Edited June 19, 2021 by Kyononono
Kyononono 0 Posted June 19, 2021 Author Posted June 19, 2021 Added my entire logs folder. Thanks for the help. logs2.zip
GrimReaper 4861 Posted June 19, 2021 Posted June 19, 2021 Well, HW acceleration is enabled, but it would seem your Turing 2080 does not support High 10 profile: >>>>>> Affected codecs Encoder NVENC NVIDIA GeForce RTX 2080 - H.264 (AVC) Adapter #0: 'NVIDIA GeForce RTX 2080' ComputeCapability: 7.5 Frame Sizes: max 4096x4096 - Width Alignment: 2 - Height Alignment: 2 Profiles: Baseline Profile (Level 6.2), Main Profile (Level 6.2), High Profile (Level 6.2), High 4:4:4 Predictive Profile (Level 6.2) Decoder NVDEC NVIDIA GeForce RTX 2080 - H.264 (AVC) Adapter #0: 'NVIDIA GeForce RTX 2080' ComputeCapability: 7.5 Frame Sizes: 48x16...4096x4096 - Width Alignment: 2 - Height Alignment: 2 Profiles: Constrained Baseline Profile (Level 6), Baseline Profile (Level 6), Main Profile (Level 6), High Profile (Level 6), Constrained High Profile (Level 6), Progressive High Profile (Level 6) >>>>>> FindVideoEncoder - Media: h264, UseHardwareCodecs: True, Mode: Automatic Info Checking: 'NVENC NVIDIA GeForce RTX 2080 - H.264 (AVC)' Info Check successful - selecting 'NVENC NVIDIA GeForce RTX 2080 - H.264 (AVC)' >>>>>> FindVideoDecoder - MediaType: h264, Mode: Automatic Info Checking: 'NVDEC NVIDIA GeForce RTX 2080 - H.264 (AVC)' NoMatch Codec does not support profile 'High 10 Profile' Info Decoder does not match Info Checking: 'DX11VA NVIDIA GeForce RTX 2080 - H.264 (AVC)' NoMatch Encoder is not compatible with 'D3d11va' decoders Info Checking: 'Automatic software decoder' Info Check successful - selecting 'Automatic software decoder' >>>>>> Processing Plan Info Name CanDoInHardware WillDoInHardware Reason Info Automatic software decoder >> False False Software Codec Info VideoInput >> False False Not a hardware decoder Info Scaling >> True True Info ColorConversion >> True True Info VideoOutput >> True True Hardware encoder Info NVENC NVIDIA GeForce RTX 2080 - H.264... >> True True Hardware Codec Anyway, @softworkz might revert on this one. 1 1
softworkz 5129 Posted June 20, 2021 Posted June 20, 2021 2 hours ago, GrimReaper76 said: Anyway, @softworkz might revert on this one. No need to. Your analysis is accurate. 1
Kyononono 0 Posted June 20, 2021 Author Posted June 20, 2021 Sorry, this is going a bit over my head. Is there anything I can do with my current setup to make this work?
