nyplayer 90 Posted June 18, 2021 Posted June 18, 2021 (edited) I was testing the converting of a recording and found out that there appears to be no CC after conversion.... Is this a known issue ? ... Watching on FireTV and Android. Edit ... Played on VLC no subtitles are being copied over. Edited June 18, 2021 by nyplayer
Luke 42203 Posted June 18, 2021 Posted June 18, 2021 Hi there, yes subtitles are supported when converting. Let's look at an example: Thanks. 1
nyplayer 90 Posted June 18, 2021 Author Posted June 18, 2021 I converted several recordings from TS to MKV and their are no subtitles in the MKV converted file ... I used the TV Profile. What more can I report you can easily test this and you will see no subtitles in the MKV file.
nyplayer 90 Posted June 18, 2021 Author Posted June 18, 2021 ffmpeg-transcode-493807ca-3b98-43e4-a929-5232737e7797_1.txt
Carlo 4561 Posted June 18, 2021 Posted June 18, 2021 24 minutes ago, nyplayer said: I converted several recordings from TS to MKV and their are no subtitles in the MKV converted file ... I used the TV Profile. What more can I report you can easily test this and you will see no subtitles in the MKV file. Are these actual subtitles or Closed Captions like from US TV recordings?
Carlo 4561 Posted June 18, 2021 Posted June 18, 2021 Closed captions are different then subtitles and are embedded in the video (line 21) and don't stand up to conversions of the video. You could use a program such as mcebuddy which I believe can extract the closed captions and rewrite them as srt files.
rbjtech 5337 Posted June 18, 2021 Posted June 18, 2021 Pretty sure the free eac3to does transport stream CC's as well :- eac3to input.ts -demux
nyplayer 90 Posted June 18, 2021 Author Posted June 18, 2021 (edited) Ok I will create a postscript using CCEEXTRACTOR then FMMPEG to Remux to MKV and not use the EMBY built in conversion. VLC has no Problem playing CC in MKV. Edited June 18, 2021 by nyplayer 2
nyplayer 90 Posted June 18, 2021 Author Posted June 18, 2021 I created a batch job that uses CCEXTRACTOR to create the srt then use FMMPEG to remux to MKV inserting the srt file in the MKV. CD /d "%~dp0" MOVE "%~f1" "%~dp1" if %ERRORLEVEL% NEQ 0 exit set filein="%~f1" if "%~x1" EQU ".ts" set fileout=%filein:.ts=.mkv% if "%~x1" EQU ".ts" set sortout=%filein:.ts=.srt% set ext=%~x1 DEL %fileout% ccextractorwinfull.exe "%~f1" ffmpeg -i %filein% -i %sortout% -c copy %fileout% SET FFMPEG=%ERRORLEVEL% IF %FFMPEG% EQU 0 DEL %filein% exit 1
