Matt7402 0 Posted October 15, 2013 Posted October 15, 2013 Well I deleted my game.xml files for the 2nd time and now they seem to be working. I curious as to why in the hell does the .xml matter in the first place?
Spanner 0 Posted October 15, 2013 Posted October 15, 2013 (edited) Having a bit of a problem after last update, I deleted both config files, deleted the library.db and removed all game.xml files but they will not repopulate for PSX, Sega mega drive or game boy colour. In the web client I can see them as game systems but with no games in them and in MBC these formats do not show up, all the other formats work fine but whatever I do I can not get these to work anymore. I am using server version 3.0.5031.21343 and gamebrowser version 2.9.5030.33786 server log https://www.dropbox.com/s/iy4vdviwmycvc1w/server-63517442474.log gamebrowser server config https://www.dropbox.com/s/1u2xi1v478d5g9v/GameBrowser%20server.xml gamebrowser mbc config https://www.dropbox.com/s/l2u0hb9c8w553mh/GameBrowser%20classic.xml Edit: Ive just notice the new game.xmls for sega master system are listed as GenesisGame in the XML is this correct https://www.dropbox.com/s/uwwgqdm4hposaas/game.xml Edited October 15, 2013 by Spanner
Redshirt 1487 Posted October 15, 2013 Author Posted October 15, 2013 Spanner, the two config xml's look fine. The 'type' value in the game.xml is correct. It's just so CoverArt uses the Sega treatment. You've re-ran the scan media library task?
Luke 42253 Posted October 15, 2013 Posted October 15, 2013 Well I deleted my game.xml files for the 2nd time and now they seem to be working. I curious as to why in the hell does the .xml matter in the first place? because when people have xml files in the directory they expect them to be utilized instead of internet data. otherwise they say why the hell aren't you using my xml files in the first place? so after we changed a couple conventions the xml files had some old data that we needed to avoid, which is why they needed to be deleted. it won't happen again.
Spanner 0 Posted October 15, 2013 Posted October 15, 2013 (edited) yeah ran it at least a dozen times, all the others work fine its just ps1, gameboy colour and sega megadrive. i have also installed the server and plugins on another machine with a copy of the roms and this doesnt create the game.xml files either. Edited October 15, 2013 by Spanner
Redshirt 1487 Posted October 16, 2013 Author Posted October 16, 2013 can you provide a server log with the task running. the first server log didn't seem to have anything
Spanner 0 Posted October 16, 2013 Posted October 16, 2013 This is from the second computer with only the server, gamebrowser server plugin, MBC and the gamebrowser MBC plugin with debug enabled. https://www.dropbox.com/s/v5acjvjayk1saf1/server-63517470355.log
Ghostm 75 Posted October 16, 2013 Posted October 16, 2013 I am new to mediabrowser, am considering switching from xbmc once mbt is available. What I am very curious about though is i have all my metadata and such for games downloaded already from emu movies, one thing thats great is the video game clips. Can any skin along with game browser support the video clips for games? Its such a nice little feature i spent time working on and am very curious.
Luke 42253 Posted October 16, 2013 Posted October 16, 2013 I am new to mediabrowser, am considering switching from xbmc once mbt is available. What I am very curious about though is i have all my metadata and such for games downloaded already from emu movies, one thing thats great is the video game clips. Can any skin along with game browser support the video clips for games? Its such a nice little feature i spent time working on and am very curious. what is your folder structure for those?
Redshirt 1487 Posted October 17, 2013 Author Posted October 17, 2013 Spanner. If you edit the two config files(gb server and gb classic) and replace "Nintendo Game Boy Color" with "Game Boy Color", that should allow those games to be discovered. I'll release a build soon that corrects the value being written to the server xml. I'm still at a complete loss as to why sega mega drive and psx games refuse to resolve.
Ghostm 75 Posted October 17, 2013 Posted October 17, 2013 (edited) I am new to mediabrowser, am considering switching from xbmc once mbt is available. What I am very curious about though is i have all my metadata and such for games downloaded already from emu movies, one thing thats great is the video game clips. Can any skin along with game browser support the video clips for games? Its such a nice little feature i spent time working on and am very curious. I will have to double check what is your folder structure for those? Just games---->n64 (for example)------->Roms------->Videoclips http://www.youtube.com/watch?v=NRTg3HmIuqU 1:05 in shows an example of how it works, it honestly sounds alot like what you can do with tv shows, only I would also like to use these clips for games. My clips are also stored on the htpc itself. Dont know if that matters though. Edited October 17, 2013 by Ghostm
Matt7402 0 Posted October 18, 2013 Posted October 18, 2013 Redshirt all my systems are still broken. I deleted both config files, deleted all xml files and all my systems but gameboy color show up. I still get the unknown error message. I have noticed that coverart normally would say "nintendo" etc on the cover image and it only says "game". Even after I deleted the xml files I think the xml files have the wrong "game system" and "type" because when I played around with a few in my nintendo section one game that did come up had <GameSystem>Nintendo</GameSystem> & <Type>NesGame</Type> but the ones that didn't work had <GameSystem>NintendoEntertainmentSystem</GameSystem> & <Type>Nintendo NES</Type>. I'll try deleting them all again for the 4th time but it seems when the system repopulates the xml files it messes those two sections up.
Luke 42253 Posted October 18, 2013 Posted October 18, 2013 Redshirt all my systems are still broken. I deleted both config files, deleted all xml files and all my systems but gameboy color show up. I still get the unknown error message. I have noticed that coverart normally would say "nintendo" etc on the cover image and it only says "game". Even after I deleted the xml files I think the xml files have the wrong "game system" and "type" because when I played around with a few in my nintendo section one game that did come up had Nintendo & NesGame but the ones that didn't work had NintendoEntertainmentSystem & Nintendo NES. I'll try deleting them all again for the 4th time but it seems when the system repopulates the xml files it messes those two sections up. delete them all again and also delete your library.db file. sorry, this was a one-time inconvenience and it won't happen again. the blame is on me in the core so don't think any differently of Redshirt's plugin.
Matt7402 0 Posted October 18, 2013 Posted October 18, 2013 Redshirt all my systems are still broken. I deleted both config files, deleted all xml files and all my systems but gameboy color show up. I still get the unknown error message. I have noticed that coverart normally would say "nintendo" etc on the cover image and it only says "game". Even after I deleted the xml files I think the xml files have the wrong "game system" and "type" because when I played around with a few in my nintendo section one game that did come up had <GameSystem>Nintendo</GameSystem> & <Type>NesGame</Type> but the ones that didn't work had <GameSystem>NintendoEntertainmentSystem</GameSystem> & <Type>Nintendo NES</Type>. I'll try deleting them all again for the 4th time but it seems when the system repopulates the xml files it messes those two sections up. Another side note I just tried the old Gamebrowser:meta program on a few games and used it to pull the meta data again it fixed those few sample games. I think the system pulling the metadata automatically is causing some if not most of everyone's issues. Just a thought.
Redshirt 1487 Posted October 18, 2013 Author Posted October 18, 2013 NOBODY USE GAMEBROWSER-META.... It's saving gamesystem values that wont be compatible with current versions of GB. @Matt. The Game Boy Color issue is actually a typo as I discussed in post #35 above. So your saying that it's the server that's writing the xml files with the incorrect values (GameSystem: Nintendo, Type: Nintendo NES). Is the files last modified date newer than when you deleted all the xml files.
Luke 42253 Posted October 18, 2013 Posted October 18, 2013 I'll take a turn and help out here. Matt7402 - if you setup a teamviewer session i'll log into it and help get you squared away.
Redshirt 1487 Posted October 18, 2013 Author Posted October 18, 2013 I've pushed a new server build that corrects the Game Boy Color typo. I'd start with that.
Matt7402 0 Posted October 18, 2013 Posted October 18, 2013 NOBODY USE GAMEBROWSER-META.... It's saving gamesystem values that wont be compatible with current versions of GB. @Matt. The Game Boy Color issue is actually a typo as I discussed in post #35 above. So your saying that it's the server that's writing the xml files with the incorrect values (GameSystem: Nintendo, Type: Nintendo NES). Is the files last modified date newer than when you deleted all the xml files. Yes the files are created after I deleted them.
Matt7402 0 Posted October 18, 2013 Posted October 18, 2013 Yes the files are created after I deleted them. What are the correct "Type" values for each system?
Luke 42253 Posted October 18, 2013 Posted October 18, 2013 What are the correct "Type" values for each system? just use mb3 to create your game.xml's and then you won't need to worry about what the values are.
Matt7402 0 Posted October 18, 2013 Posted October 18, 2013 The latest update resolved all the games except gameboy color. I've deleted all xml for both games and system with no luck on the GBC.
Matt7402 0 Posted October 18, 2013 Posted October 18, 2013 just use mb3 to create your game.xml's and then you won't need to worry about what the values are. Luke I've tried that method before. I deleted the old xml files and then let mb3 generate new ones and it still doesn't create the proper file types for NDS, SNES, NES, N64, NGC, GBC, GBA, WII, PS2, PS1, and Genesis. Now I've figured out the types for the following ones but the remainder are not properly generating. NES: Nesgame N64: N64game GB: GameBoyGame
Luke 42253 Posted October 18, 2013 Posted October 18, 2013 you need to delete them, the gamesystem.xml files and the library db at the same time. if they weren't all at the same time it's not going to work.
Redshirt 1487 Posted October 19, 2013 Author Posted October 19, 2013 You've upgraded to gamebrowser server version 2.9.5038.32002? Can you verify that the gamebrowser.xml in the servers plugins\configurations folder has "Game Boy Color" for the ConsoleType.
Spanner 0 Posted October 19, 2013 Posted October 19, 2013 latest gb build has fixed my issue with gameboy colour but not the sega mega drive or psx
