oxhey 1 Posted June 17, 2021 Posted June 17, 2021 (edited) I just got my Xbox Series X and have decided that I would like it to be the sole destination for all the media apps (Prime, Netflix, YouTube etc...) instead of having these apps installed on my LG TV. I'm running into an issue with emby where playback is unexpectedly choppy and there is noticeable stutter even though files are direct playing. I have attached a screenshot of the media information for a TV episode where this choppiness is noticeable right from the start. It's worth mentioning that playback is fine on the Plex app on the Xbox as well as on the LG emby app. The Xbox has options to enable other video modes. See the second screenshot as an example. I have all but the last of each row enabled on my system. Disabling these makes no difference. My suspicion is that emby isn't correctly telling the Xbox which framerate it wants. Edited June 17, 2021 by oxhey
Luke 42239 Posted June 23, 2021 Posted June 23, 2021 Hi there, can you please attach the log files from an example? Thanks !
oxhey 1 Posted June 23, 2021 Author Posted June 23, 2021 (edited) @Luke Fresh log attached. It's just the first few seconds from the Loki episode mentioned above, so hopefully its enough, however nothing jumps out at me in the log. Should note that this file works fine on the Windows App and on the LG app and like I said above I think it could be something to do with the Xbox series X video modes. Hope this can be resolved. embyserver.txt Edited June 24, 2021 by oxhey
Luke 42239 Posted July 12, 2021 Posted July 12, 2021 Hi @oxhey, are you still having an issue with this?
MBSki 1115 Posted July 12, 2021 Posted July 12, 2021 @Luke Have you added audio passthrough and adjusted the audio transcoding settings? If you haven't, we still won't be able to play 4k videos.
oxhey 1 Posted July 12, 2021 Author Posted July 12, 2021 (edited) The frame rate issue is also happening with 1080p video. Like I said said above, may have something to do with emby telling the Xbox which frame rate it should be using. Edited July 12, 2021 by oxhey
