justinrh 267 Posted June 16, 2021 Posted June 16, 2021 (edited) Is there a better way to scroll the guide horizontally than trying to drag this tiny puck at the bottom of the TV guide page? To be sure, this is in the web player.  It was getting too quiet around here, so I had to ask something Edited June 16, 2021 by justinrh
Luke 42243 Posted June 16, 2021 Posted June 16, 2021 Hi, what way would you prefer? Where is it getting too quiet?
justinrh 267 Posted June 16, 2021 Author Posted June 16, 2021 (edited) I think a big arrow button on either side of the page would be handy-dandy. It could be a persistent button or a popup-overlay button upon hover near the sides. Edited June 16, 2021 by justinrh 1
Carlo 4561 Posted June 17, 2021 Posted June 17, 2021 Just to let you know if using a notebook with a track pad you can use 2 fingers on the trackpad and easily scroll left and right. Same as using a touch screen where you can touch the screen and scroll it. If using a conventional mouse you can hold the SHIFT key and then use the scroller which will scroll left and right vs up and down. Lastly you can also use the left and right arrow keys on the keyboard as well. Let us know if this helps.
justinrh 267 Posted June 18, 2021 Author Posted June 18, 2021 (edited) @cayars Those are helpful hints. I did find a bug with the keyboard cursor keys. open browser, browse to Emby, select "Live TV", cursor right a few times - the scroll stops and won't go further (it stops at 2AM for me, starting at 7:PM) Once you force it to go further, like cursor down or scroll the puck, it works as expected and won't get stuck for that session.  Edited June 18, 2021 by justinrh
Carlo 4561 Posted June 18, 2021 Posted June 18, 2021 Yes you're correct, I can reproduce this on 4.7.0.3 as well. @Luke 1
