Danimontes 11 Posted June 28, 2021 Author Posted June 28, 2021 32 minutes ago, cayars said: Can you show us what these look like please? Ésta, por ejemplo, no carga las imágenes. Screenrecorder-2021-06-29-00-00-06-333.mp4
Carlo 4561 Posted June 28, 2021 Posted June 28, 2021 No I mean the files on disc. We would like to see the folder structure and file naming being used.
Danimontes 11 Posted June 28, 2021 Author Posted June 28, 2021 Maybe I didn't explain myself well. Before I suffered the "blocked DNS" problem, all movies were well imaged. Everything worked fine. I haven't modified anything in the file structure nor names. All weird things happened since ten days ago.
Carlo 4561 Posted June 28, 2021 Posted June 28, 2021 Can you run a library scan and then upload your server log again. Let's take a look at see what's going on.
Danimontes 11 Posted June 29, 2021 Author Posted June 29, 2021 19 hours ago, cayars said: Can you run a library scan and then upload your server log again. Let's take a look at see what's going on. Here you have. Thanks. embyserver.txt
Carlo 4561 Posted June 29, 2021 Posted June 29, 2021 You log is littered with errors from trying to auto port map. Can you turn off Networks->Enable automatic port mapping Then go to schedule tasks and rotate you log Then scan again and upload the new cleaner log file.
Danimontes 11 Posted June 30, 2021 Author Posted June 30, 2021 10 hours ago, cayars said: You log is littered with errors from trying to auto port map. Can you turn off Networks->Enable automatic port mapping Then go to schedule tasks and rotate you log Then scan again and upload the new cleaner log file. Done. Here again. embyserver (2).txt
Carlo 4561 Posted June 30, 2021 Posted June 30, 2021 Log is much cleaner now. Can you try using multi-select to select 20 movies or so with bad images, then using the 3 dot menu refresh meta-data replacing images on them. After it completes go back to the home screen then back into movies to check on them. If this doesn't work, upload a new log. 1
Luke 42241 Posted July 1, 2021 Posted July 1, 2021 @Danimontes please let us know if this helps. Thanks !
Danimontes 11 Posted July 1, 2021 Author Posted July 1, 2021 (edited) Yeah, That worked well!! But it should do it automatically, right? Always did it. Edited July 1, 2021 by Danimontes 1
Carlo 4561 Posted July 1, 2021 Posted July 1, 2021 Yes it should have worked outright but apparently something got in the way during the initial loading. A library refresh would likely have fixed this but using the multi-select (depending on quantity) is sometimes easier/faster. But anyway, glad you got this fixed up and working now!
