mankls 0 Posted June 16, 2021 Posted June 16, 2021 Hello, i tried to set up my emby server on a vps (lxc). I get the following Error in log: 2021-06-16 07:36:31.726 Error LiveTV: Error getting channels *** Error Report *** Version: 4.6.2.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Linux version 5.4.101-1-pve (build@pve) (gcc version 8.3.0 (Debian 8.3.0-6)) #1 SMP PVE 5.4.101-1 (Fri, 26 Feb 2021 13:13:09 +0100) Framework: .NET Core 3.1.13 OS/Process: x64/x64 Runtime: opt/emby-server/system/System.Private.CoreLib.dll Processor count: 4 Data path: /var/lib/emby Application path: /opt/emby-server/system System.IO.InvalidDataException: System.IO.InvalidDataException: The archive entry was compressed using an unsupported compression method. at System.IO.Compression.Inflater.Inflate(FlushCode flushCode) at System.IO.Compression.Inflater.ReadInflateOutput(Byte* bufPtr, Int32 length, FlushCode flushCode, Int32& bytesRead) at System.IO.Compression.Inflater.ReadOutput(Byte* bufPtr, Int32 length, Int32& bytesRead) at System.IO.Compression.Inflater.InflateVerified(Byte* bufPtr, Int32 length) at System.IO.Compression.DeflateStream.FinishReadAsyncMemory(ValueTask`1 readTask, Memory`1 buffer, CancellationToken cancellationToken) at System.IO.StreamReader.ReadBufferAsync(CancellationToken cancellationToken) at System.IO.StreamReader.ReadLineAsyncInternal() at Emby.LiveTV.TunerHosts.M3uParser.GetChannels(TextReader reader, String channelIdPrefix, String tunerHostId) at Emby.LiveTV.TunerHosts.M3uParser.Parse(String url, String userAgent, String channelIdPrefix, String tunerHostId, CancellationToken cancellationToken) at Emby.LiveTV.TunerHosts.M3UTunerHost.GetChannelsInternal(TunerHostInfo info, CancellationToken cancellationToken) at Emby.LiveTV.TunerHosts.BaseTunerHost.GetChannels(TunerHostInfo host, CancellationToken cancellationToken) at Emby.LiveTV.TunerHosts.BaseTunerHost.GetChannels(TunerHostInfo host, CancellationToken cancellationToken) at Emby.LiveTV.EmbyTV.GetTunerChannelsAsync(CancellationToken cancellationToken) Source: System.IO.Compression TargetSite: ErrorCode Inflate(FlushCode) How can I solve this ? Thanks ...
Luke 42246 Posted June 16, 2021 Posted June 16, 2021 Hi there @mankls, are you experiencing a problem?
mankls 0 Posted June 17, 2021 Author Posted June 17, 2021 Yes Emby does not scan live tv because of that.
Luke 42246 Posted June 18, 2021 Posted June 18, 2021 Please attach the complete emby server log. thanks.
mankls 0 Posted June 18, 2021 Author Posted June 18, 2021 Here is the log. I can reproduce the error when i click on update program data in the live tv setup menu. Sorry for my english ... emby.txt
Luke 42246 Posted June 21, 2021 Posted June 21, 2021 The m3u url might be using a type of compression that we don't currently support. If you can PM me the url, then I'll test it out. Thanks.
