wmcig2020 0 Posted June 16, 2021 Posted June 16, 2021 I use the DLNA plugin to stream my music to another box. This works. But what doesn't work when using DLNA are the following options: - Add to playlist - Play next - Play all from here - Shuffle As soon as I select a song to end up in the playlist, it is immediately selected and played. It's the same with the other functions. If I turn off DLNA or don't use it, then I can use the above features without any problems. For me it is a bug that should be fixed. My Emby version is up to date.
Luke 42255 Posted June 16, 2021 Posted June 16, 2021 Hi, yes these functions haven't been fully implemented for Dlna yet, but they're planned for the future. Thanks.
