byakuya32 24 Posted June 16, 2021 Author Posted June 16, 2021 7 minutes ago, softworkz said: Thanks! This case is resolved. The issue was that you had chosen the non-default CUVID HEVC decoder which is known to have some issues. That it can create such huge memory leaks is something that we hadn't seen before, though. Thanks for your patience and working with us to resolve this. thanks I was choosing let the software choose which one it thinks was best for the file.
softworkz 5133 Posted June 16, 2021 Posted June 16, 2021 2 minutes ago, byakuya32 said: thanks I was choosing let the software choose which one it thinks was best for the file. That's the "Yes" setting for transcoding, but you had chosen the "Advanced" setting and then the other decoder. Normally, the worst outcome of that is a greenish picture or some green visual artifacts, but a massive memory leak is something new. Just for reference: which version of the Nvidia driver did you install and from where/how did you install it?
byakuya32 24 Posted June 16, 2021 Author Posted June 16, 2021 1 minute ago, softworkz said: That's the "Yes" setting for transcoding, but you had chosen the "Advanced" setting and then the other decoder. Normally, the worst outcome of that is a greenish picture or some green visual artifacts, but a massive memory leak is something new. Just for reference: which version of the Nvidia driver did you install and from where/how did you install it? I am running on driver 440.100
softworkz 5133 Posted June 16, 2021 Posted June 16, 2021 The latest version for your hardware if 460.84: https://www.nvidia.com/Download/driverResults.aspx/175875/en-us (maybe this resolves the CUVID memory leak issue)
