softworkz 5133 Posted June 16, 2021 Posted June 16, 2021 That latest log looks good! No degradation of speed..
softworkz 5133 Posted June 16, 2021 Posted June 16, 2021 You said: 26 minutes ago, byakuya32 said: same thing but to me it looks like that switching to NVDEC (which is the default by the way) has fixed the problem. Am I right?
byakuya32 24 Posted June 16, 2021 Author Posted June 16, 2021 4 minutes ago, softworkz said: That latest log looks good! No degradation of speed..
byakuya32 24 Posted June 16, 2021 Author Posted June 16, 2021 Just now, byakuya32 said: its just doing this and not actually running
byakuya32 24 Posted June 16, 2021 Author Posted June 16, 2021 also no new ffmpeg logs the process does not seem to be starting
softworkz 5133 Posted June 16, 2021 Posted June 16, 2021 What's the current state of changes you made? We should go back to the state from where the latest log was that you posted: after you changed the decoder from CUVID to NVDEC.
byakuya32 24 Posted June 16, 2021 Author Posted June 16, 2021 that was with software and durring all the changes I never saw a process for ffmpeg start so I have no idea what settings created the log
softworkz 5133 Posted June 16, 2021 Posted June 16, 2021 I would delete that whole conversion queue and initiate a new (single) conversion. Otherwise we don't have a consistent test subject.
softworkz 5133 Posted June 16, 2021 Posted June 16, 2021 The log wasn't with software encoding or decoding, it was full hw transcoding: You didn't see it, because it was at the bottom of the list as it didn't have much CPU usage.
byakuya32 24 Posted June 16, 2021 Author Posted June 16, 2021 2 minutes ago, softworkz said: The log wasn't with software encoding or decoding, it was full hw transcoding: You didn't see it, because it was at the bottom of the list as it didn't have much CPU usage. it doesn't seem to be making a log with software only hardware
softworkz 5133 Posted June 16, 2021 Posted June 16, 2021 1 minute ago, byakuya32 said: it doesn't seem to be making a log with software only hardware No, it always creates an ffmpeg log when ffmpeg is run.
byakuya32 24 Posted June 16, 2021 Author Posted June 16, 2021 Just now, byakuya32 said: I see the process but It does not seem to be doing anything
byakuya32 24 Posted June 16, 2021 Author Posted June 16, 2021 Just now, softworkz said: No, it always creates an ffmpeg log when ffmpeg is run. yea it should but wouldn't mean that if there is no log something is preventing it from starting in software mode
softworkz 5133 Posted June 16, 2021 Posted June 16, 2021 Just now, byakuya32 said: yea it should but wouldn't mean that if there is no log something is preventing it from starting in software mode Anyway, we found out that using NVDEC+NVENC is working. Why aren't you trying this again?
byakuya32 24 Posted June 16, 2021 Author Posted June 16, 2021 2 minutes ago, softworkz said: Anyway, we found out that using NVDEC+NVENC is working. Why aren't you trying this again? I have it on that setting now it creates a log file but the progress bar does not even start
softworkz 5133 Posted June 16, 2021 Posted June 16, 2021 (edited) 1 minute ago, byakuya32 said: I have it on that setting now it creates a log file but the progress bar does not even start Let's focus on the log, IIRC, the progress updates have never been working 100% reliably. Edited June 16, 2021 by softworkz
byakuya32 24 Posted June 16, 2021 Author Posted June 16, 2021 Just now, softworkz said: Let's focus on the log, IIRC, the progress updates have never been working 100% reliable. True progress bars are never 100% reliable but shouldn't there be a start to the movement to show that something is happening. and how do you tell when it is done with the log?
softworkz 5133 Posted June 16, 2021 Posted June 16, 2021 1 minute ago, byakuya32 said: True progress bars are never 100% reliable but shouldn't there be a start to the movement to show that something is happening. and how do you tell when it is done with the log? All good questions that I can't answer. I can only help with the transcoding part You can open the log while ffmpeg is still running, to verify that it's not degrading performance anymore, though.
byakuya32 24 Posted June 16, 2021 Author Posted June 16, 2021 1 minute ago, softworkz said: All good questions that I can't answer. I can only help with the transcoding part You can open the log while ffmpeg is still running, to verify that it's not degrading performance anymore, though.
byakuya32 24 Posted June 16, 2021 Author Posted June 16, 2021 Just now, byakuya32 said: this bar seems to move with these settings. Something seems to be broken. Maybe a patch is needed.
byakuya32 24 Posted June 16, 2021 Author Posted June 16, 2021 Just now, softworkz said: How does the log file look like? ffmpeg-transcode-dc2005d5-9597-42bc-bf6c-30ed324bf09b_1.txt embyserver (1).txt
Solution softworkz 5133 Posted June 16, 2021 Solution Posted June 16, 2021 Thanks! This case is resolved. The issue was that you had chosen the non-default CUVID HEVC decoder which is known to have some issues. That it can create such huge memory leaks is something that we hadn't seen before, though. Thanks for your patience and working with us to resolve this.
