byakuya32 24 Posted June 15, 2021 Posted June 15, 2021 My emby convert is not running it just show a progress bar and stalls. Here are the logs. ffmpeg-transcode-67cf9fa6-f752-4cc2-9cf4-309763defba8_1.txt embyserver.txt
Q-Droid 1011 Posted June 15, 2021 Posted June 15, 2021 Convert is running but very slowly. It looks like your GPU can't handle the task. Had you been able to convert 4k HEVC before and had you noticed the rate (fps) or speed (x)?
byakuya32 24 Posted June 15, 2021 Author Posted June 15, 2021 it hasn't moved at all since the 6.0.2 update it was working fine before that. I have the quadro m2000. Before that update it was doing movies in 10 to 15 minutes.
Luke 42246 Posted June 16, 2021 Posted June 16, 2021 Hi, try turning off transcoding tone mapping. That is the difference from 4.5.
byakuya32 24 Posted June 16, 2021 Author Posted June 16, 2021 59 minutes ago, Luke said: Hi, try turning off transcoding tone mapping. That is the difference from 4.5. @Luke Tone mapping is disabled
Luke 42246 Posted June 16, 2021 Posted June 16, 2021 Please attach both the server and ffmpeg log files from an example as the ffmpeg log file alone doesn't show the full picture. Thanks.
byakuya32 24 Posted June 16, 2021 Author Posted June 16, 2021 Here is all 3 logs hardware_detection-63759352166.txt ffmpeg-transcode-67cf9fa6-f752-4cc2-9cf4-309763defba8_1.txt embyserver.txt
softworkz 5133 Posted June 16, 2021 Posted June 16, 2021 @byakuya32 - Could you please run "top" while ffmpeg is running and check its memory and CPU usage?
softworkz 5133 Posted June 16, 2021 Posted June 16, 2021 Also, why did you select 'CUVID Quadro M2000 - H.265 (HEVC)' instead of the NVDEC variant?
softworkz 5133 Posted June 16, 2021 Posted June 16, 2021 Just now, byakuya32 said: Here is a screenshot OK thanks, that look very wrong...
byakuya32 24 Posted June 16, 2021 Author Posted June 16, 2021 I do not see an option in transcodeing for nvdec
softworkz 5133 Posted June 16, 2021 Posted June 16, 2021 Just now, softworkz said: Also, why did you select 'CUVID Quadro M2000 - H.265 (HEVC)' instead of the NVDEC variant? What happens when you choose 'NVDEC' for H.265 decoding (or just "Yes" instead "Advanced" for the HWA configuration)?
softworkz 5133 Posted June 16, 2021 Posted June 16, 2021 1 minute ago, byakuya32 said: I do not see an option in transcodeing for nvdec Could you post a screenshot from the H.265 section? (or the hw detection log)
byakuya32 24 Posted June 16, 2021 Author Posted June 16, 2021 4 minutes ago, softworkz said: Could you post a screenshot from the H.265 section? (or the hw detection log) Here is the screenshot and I have already posted the hardware detection log.
softworkz 5133 Posted June 16, 2021 Posted June 16, 2021 Sorry, I mean the Transcoding settings page on the server dashboard.
byakuya32 24 Posted June 16, 2021 Author Posted June 16, 2021 2 minutes ago, softworkz said: Here you go
softworkz 5133 Posted June 16, 2021 Posted June 16, 2021 Great! Now disable CUVID (just to be sure) and retry the conversion. (don't forget to click Save)
softworkz 5133 Posted June 16, 2021 Posted June 16, 2021 OK, thanks for trying. We have a gigantic memory leak and CUVID was the most likely candidate. Next steps we need to try to find the cause: Try to use software decoding => disable all checkmarks for H.265 hardware decoders and retry Try to use software encoding => Disable the H.264 Nvidia encoder to enforce libx264 encoding In all cases, check ffmpeg memory usage (high CPU usage will be normal with sw transcoding, though)
byakuya32 24 Posted June 16, 2021 Author Posted June 16, 2021 9 minutes ago, softworkz said: OK, thanks for trying. We have a gigantic memory leak and CUVID was the most likely candidate. Next steps we need to try to find the cause: Try to use software decoding => disable all checkmarks for H.265 hardware decoders and retry Try to use software encoding => Disable the H.264 Nvidia encoder to enforce libx264 encoding In all cases, check ffmpeg memory usage (high CPU usage will be normal with sw transcoding, though) does not seem like the process is starting
softworkz 5133 Posted June 16, 2021 Posted June 16, 2021 Just go to "Log" in the Emby dashboard UI and see whether a new ffmpeg log was created. Besides that: How about other operations with HW acceleration in Emby server? Does that work, did you try? I mean: are all operations with Nvidia hwa affected or only this specific conversion case?
byakuya32 24 Posted June 16, 2021 Author Posted June 16, 2021 this might help but the transcoding-temp folder is empty
byakuya32 24 Posted June 16, 2021 Author Posted June 16, 2021 Here is the latest log ffmpeg-transcode-a946a263-93f8-41e6-97c0-285f76aa0af8_1.txt
